format field
5057
16
08-28-2020 11:57 AM
2Quiker
Trying to format a field but I am not sure how accomplish it. The trouble I am having is the making the second to last 0 a space but only if there is no alph char. WellPin field is always 10 numbers and sometimes with an alph char. Can someone help me out by showing me how to do this with updatecurosr and in a filed calculator please?
Well                      WPin
W1234500000 -->    12345000 0
W1234501000-->     12345010 0
W12345010S0-->     12345010S0
W12345010S1-->     12345010S1
Here what I have so far.
import arcpy
fc = r"C:\Temp\Wells.shp"
count = 0
def maketv_cursor(fc):
    rows = arcpy.SearchCursor(table,"WPin")
    count = 0
    for row in rows:
        count += 1
#print(count)
with arcpy.da.UpdateCursor(fc,['WellID','WPin']) as cursor:
    for row in cursor: #if row[0] in (None, "", " "):
        row [1] = (row[0][1:11]) # Field Calculator!WellID! [1:11]
        cursor.updateRow(row)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
2Quiker
After your suggestion I am getting error 000539 invalid syntax expression line 1.
JoshuaBixby
MVP Esteemed Contributor
Looking at your screenshot from earlier, you are also trying to define a function in the expression box.
Your expression should be:
conv(!WellID!)
and your pre-script code should be:
import string
nums = string.digits
def conv(WellID):
    """docstring"""
  if WellID[-2] in nums:
    return "{} {}".format(WellID[1:-2], WellID[-1:])
  else:
    return WellID[1:]
JoshuaBixby
If it has to be an update cursor, try:
import arcpy
    for wellid, wpin in cursor:
        if wellid not in (None, "", " "):
            i,j,k = wellid[:-2], wellid[-2], wellid[-1:]
            wpin = "{}{}{}".format(i, j if not j.isdigit() else " ", k)
            cursor.updateRow([wellid, wpin])‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
RandyBurton
Joshua Bixby‌   If the goal is to keep the letter and drop the zero from the next to last position, shouldn't line 9 be ("not" isdigit) ?
JoshuaBixby
Randy Burton‌, good catch, I got mixed up on what the OP was after.  You are correct, I have updated my code snippet.  Thanks.
2Quiker
This worked, although would it be best to do just do it through Calculate field management.
DanPatterson
import string
def conv( WellID , nums):
    """docstring"""
    if !WellID! [-2] in nums: # two space indents
        return "{} {}".format( !WellID! [1:-2], !WellID! [-1:])#four spaces indents
    else: # two space indents
        return !WellID! [1:]#four spaces indents
... sort of retired...
