format field
5080
16
08-28-2020 11:57 AM
2Quiker
Trying to format a field but I am not sure how accomplish it. The trouble I am having is the making the second to last 0 a space but only if there is no alph char. WellPin field is always 10 numbers and sometimes with an alph char. Can someone help me out by showing me how to do this with updatecurosr and in a filed calculator please?
Well                      WPin
W1234500000 -->    12345000 0
W1234501000-->     12345010 0
W12345010S0-->     12345010S0
W12345010S1-->     12345010S1
Here what I have so far.
import arcpy
arcpy.env.overwriteOutput = True
fc = r"C:\Temp\Wells.shp"
count = 0
def maketv_cursor(fc):
    rows = arcpy.SearchCursor(table,"WPin")
    count = 0
    for row in rows:
        count += 1
#print(count)
with arcpy.da.UpdateCursor(fc,['WellID','WPin']) as cursor:
    for row in cursor: #if row[0] in (None, "", " "):
        row [1] = (row[0][1:11]) # Field Calculator!WellID! [1:11]
        cursor.updateRow(row)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
JoshuaBixby
MVP Esteemed Contributor
If it has to be an update cursor, try:
import arcpy
    for wellid, wpin in cursor:
        if wellid not in (None, "", " "):
            i,j,k = wellid[:-2], wellid[-2], wellid[-1:]
            wpin = "{}{}{}".format(i, j if not j.isdigit() else " ", k)
            cursor.updateRow([wellid, wpin])‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
RandyBurton
A quick example (using underscore for space):
rows = [['W1234500000',],
        ['W1234501000',],
        ['W12345010S0',],
        ['W12345010S1',] ]
for row in rows:
    if row[0][10] == '0':
        print(row[0][:9]+"_"+row[0][-1:])
    else:
        print(row[0])
prints:
W12345000_0
W12345010_0
W12345010_0
W12345010S1‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
2Quiker
I am getting error string index out of range on line 5.
Also the "_" to " " because i need the space not the underscore.
dict = {r[0]:(r[1:]) for r in arcpy.da.SearchCursor(fc,['WellID','WPin'])}
    for row in cursor:
            #print(row[0][:9]+"_"+row[0][-1:])
            row [1] = row[0][:9]+" "+row[0][-1:]
        else:
            print(row[0])
DanPatterson
w0 = "W1234500000"
w1 = "W12345010S0"
import string
nums = string.digits
def conv(fld, nums):
    """docstring"""
    if fld[-2] in nums:
        return "{} {}".format(fld[1:-2], fld[-1:])
    else:
        return fld[1:]
conv(w0, nums)
'12345000 0'
conv(w1, nums)
'12345010S0'
... sort of retired...
2Quiker
I am kind of lost on this one because it's not formatted with updatecusror, can you explain what's going on please?
DanPatterson
Use the Calculate Field or the just the field calculator.  I see little reason to use a search cursor on this.
besides, your 'row' is my 'fld' and I use a different means of slicing that relies less on string length but more on string head/tail positions of the things to change.  I am sure you will see upon closer examination
2Quiker
I am getting error 000989. If and else have two indent and the return have 4 indents.
Field Calculator
import string
def conv( WellID , nums):
    """docstring"""
  if !WellID! [-2] in nums: # two space indents
    return "{} {}".format( !WellID! [1:-2], !WellID! [-1:])#four spaces indents
  else: # two space indents
    return !WellID! [1:]‍‍‍‍‍‍‍‍‍#four spaces indents
 Code Block
DanPatterson
indent it properly then, like in my example
2Quiker
I have but for some reason it won't work no matter how many spaces(indents) I put in, in line 6 gives me the same error.
JoshuaBixby
One problem you have is with your variable names.  You don't put the field name in exclamations in the function definition.  For example, don't do !WellID! and instead do WellID.
