Force labels to show
1383
03-04-2014 10:03 AM
DannyLackey
For the map I'm creating, it's quite zoomed out with all icons/labels appearing quite small (which is what I need).  As small as they are, there are still a few labels that won't show up unless I increase this
df_export_width=20000, df_export_height=20000
.  At this level, the icons dont even touch eachother.  Is there a line I can add to force the labels to show no matter how close the icons are?  Googled around for it, but no luck so far.  Is there a way to programmatically change the label weight?
thx
JoshuaChisholm
Hello Danny,
I think that has to be done manually in ArcMap:
Layer Properties > Labels tab > Placement Properties > Conflict Detection tab > Place overlapping labels
Good luck!
DannyLackey
Hello Danny,
Good luck!
Thank you.  Hoping this isn't the case.  How about programmatically enabling overlapping labels, then disabling at the end?
DannyLackey
No luck so far.  Sounds like it may have something to do with conflict_distance?
Found this, but seems to be in a different language?  Or at least in a different format than I'm used to.  not sure how to apply within my code.  Tried a few things, failed.
http://forums.arcgis.com/threads/69295-how-to-overlap-labels
