For the ArcMap 10.5, "load Objects" tool arcpy codes
823
09-22-2024 11:52 PM
baohuachu2
I'm newbie in ArcPy. Is there any APIS the same as "load Objects"(in ArcMap customize mode can find it)?
I want to load features participated in geometric network.
BruceBacia
I have automated scripts that load features into a geometric network.  I use the Append (Data Management)—ArcMap | Documentation (arcgis.com) tool to load features.  You would likely need to open an edit session on the target database for this, as well.  Example below.
One thing to note - I found that the append method works well if loading less than 10,000 features.  Once you get over this, it would really slow down.  So, if you have a lot of features, you may want to break them up into subsets of 10,000 features and perform an append of each subset into the network.
with arcpy.da.Editor(target_db_conx_file) as edit:
            script.logger.info('Appending new meters to target feature class: ' + target_meters_fc)
            arcpy.management.Append(inputs=new_meters_fc, target=target_meters_fc, schema_type='NO_TEST')
            script.logger.info('Successfully appended new meters to target feature class: ' + target_meters_fc)
