For Loop and Python String format()
9464
13
03-25-2020 08:10 AM
NataliaGutierrez1
I am trying to use UpdateCursor to update a field value by evaluating the value of another field. I have to do this in about 70 feature classes. For this reason I am using For Loop as well.
This is the script:
import arcpy
arcpy.env.workspace = r"D:\APRX_MXDS\USA_Parcels_2019_Project\Test.gdb"
List_dissolve_fc = arcpy.ListFeatureClasses("*Dissolve")  # get a list of feature classes that end with "Dissolve"
fields = ["CO_NO", "COUNTY_NAME"]  # List of fields in test.gdb
for fc in List_dissolve_fc:  # Loop through each feature class in the list
    with arcpy.da.UpdateCursor(fc, fields) as cursor: # Loop through each feature
        for row in cursor:
            if (row[1] == "{}".format(fc[:-17])): # if COUNTY_NAME equals the name of the feature class without the last 17 characters, assign 74 to field CO_NO
                row[0] = 11
            elif (row[1] == "{}".format(fc[:-17])):
                row[0] = 12
                row[0] = 13
                row[0] = 14
                row[0] = 15
                row[0] = 16
                row[0] = 17
                row[0] = 18
                row[0] = 19
                row[0] = 20
                row[0] = 21
                row[0] = 22
                row[0] = 23
                row[0] = 24
                row[0] = 25
                row[0] = 26
                row[0] = 27
                row[0] = 28
                row[0] = 29
                row[0] = 30
                row[0] = 31
                row[0] = 32
                row[0] = 33
                row[0] = 34
                row[0] = 35
                row[0] = 36
                row[0] = 37
                row[0] = 38
                row[0] = 39
                row[0] = 40
                row[0] = 41
                row[0] = 42
                row[0] = 43
                row[0] = 44
                row[0] = 45
                row[0] = 46
                row[0] = 47
                row[0] = 48
                row[0] = 49
                row[0] = 50
                row[0] = 51
                row[0] = 52
                row[0] = 53
                row[0] = 54
                row[0] = 55
                row[0] = 56
                row[0] = 57
                row[0] = 58
                row[0] = 59
                row[0] = 60
                row[0] = 61
                row[0] = 62
                row[0] = 63
                row[0] = 64
                row[0] = 65
                row[0] = 66
                row[0] = 67
                row[0] = 68
                row[0] = 69
                row[0] = 70
                row[0] = 71
                row[0] = 72
                row[0] = 73
                row[0] = 74
                row[0] = 75
                row[0] = 76
                row[0] = 77
            else:
                row[0] = None
                cursor.updateRow(row)
Expected behavior:
With the String format() method I am trying to do the following:
For every feature class whenever row[1] matches the name of the feature class minus the last 17 characters, assign the specified number to row[0]. I am expecting every feature class to only have one match and as a result one number will be assigned to row[0].
Actual Behavior:
I am getting the expected behavior but only in the last feature class on the list "List_dissolve_fc".
I know there is something very obvious to all of this but I cannot have a clear picture of what it is.
How could I solve this?
Thank you,
Natalia
JoeBorgione
Randy Burton‌ ; that's the solution right there!
NataliaGutierrez1
Thank you for your help!
Learning a lot with this.
RandyBurton
Keep learning! And have fun doing it!
NataliaGutierrez1
I always try! thanks!
