Fine Tune Project line
1608
10-11-2016 11:01 PM
KevinLam
I have a project limit that cut some land parcel boundaries. The original design of the project limit should be coincident with the land parcel boundaries. How can I fine tune the project limit programmatically to follow/snap land parcel boundaries to prevent gaps or cross over. Thanks
Tags (1)
DanPatterson_Retired
why do you need to do it via script? and do none of the overlay tools do what you want?  The latter can be used in python as part of a workflow
NeilAyres
Or just use the spatial select tools to select the underlying parcels within and on the edge of your project area, then save them out and dissolve all together to get a project boundary that matches the parcels.
