Finding an Average Rainfall Data
3271
11
05-02-2012 11:46 AM
RPatarasuk
Hi All,
I have about 350 files of PRISM rainfall data to process. I have e.g. precip from 1970 - 2010. and each year has 13 files.
ppt_1970.01.tif
ppt_1970.02.tif
ppt_1970.03.tif
ppt_1970.04.tif
ppt_1970.05.tif
ppt_1970.06.tif
ppt_1970.07.tif
ppt_1970.08.tif
ppt_1970.09.tif
ppt_1970.10.tif
ppt_1970.11.tif
ppt_1970.12.tif
ppt_1970.14.tif
ppt_2010.11.tif
ppt_2010.12.tif
ppt_2010.14.tif
I try to write a python code to calculate a long term average. Here is the code that I have so far. I have only tried to play around with 5-10 files and the program only returns values for the last file (i.e. it doesn't add up the values of previous file and find the average). Also, I would like to exclude "*.14" from the calculation.
# Import system modules
import arcpy
from arcpy import env
from arcpy.sa import *
# Check out the ArcGIS Spatial Analyst extension license
arcpy.CheckOutExtension("Spatial")
# Input data source
arcpy.env.workspace = "S:/Work/Risa/Trial & Error/input"
arcpy.env.overwriteOutput = True
# Set output folder
OutputFolder = "S:/Work/Risa/Trial & Error/output/"
# Loop through a list of files in the workspace
rasterFiles = arcpy.ListRasters()
# Local variables:
for filename in rasterFiles:
    print("Processing: " + filename)
    inRaster = arcpy.env.workspace + "/" + filename
    outRaster = OutputFolder + "/" + "AvgPrecip.tif"
    #***need to process from all of the files except the ones that have "*.14"
    # Process: Cell Statistics
    arcpy.gp.CellStatistics_sa(inRaster, outRaster, "MEAN", "DATA")
print "***DONE!!!"
Any help would be very appreciated. Thank you very much.
Risa
PhilMorefield
First, please use CODE tags when you post actual Python code: http://forums.arcgis.com/threads/48475-Please-read-How-to-post-Python-code
Second, the "14" file that you want to exclude is actually the annual average. No need to include the other 12 files for each year.
Third, in answer to your question you could do something like this:
inList = []
    if filename.endswith('14'):
        inList.append(filename)
arcpy.sa.CellStatistics(inList, outRaster, "MEAN", "DATA")  # this line was incorrect in your example
RPatarasuk
Dear philmorefield,
Thank you very  much for your help. I am very new to python and how to post the questions on the Forum. I tried to incorporated what you suggested but still has no luck. It doesn't append *.14 and it also calculates only the last file processed. Here is the code that I modified.
import arcpy
# Input data source
# Set output folder
# Local variables:
    if filename.endswith("*.14.tif"):
        inRaster.append(filename)
    outRaster = CellStatistics(inRaster, "MEAN", "DATA")
    # Save the output
    outRaster.save("S:/Work/Risa/Trial & Error/output/AvgPrecip01.tif")
print "Average Calculated!!!"
PhilMorefield
There are a couple of problems that need to be addressed. I put in some comments to help explain.
import arcpy
# Input data source
arcpy.env.workspace = "S:/Work/Risa/Trial_and_Error/input"  # don't use spaces or special characters in path names
# Set output folder
OutputFolder = "S:/Work/Risa/Trial_and_Error/output/"
# The loop does nothing else but build the list
inRasters = []  # you need to do this outside of the loop
    if filename.endswith("14.tif"):
        inRasters.append(filename)
# Now we have a list of the files we want to average, but you only need to calculate the average once,
# which means this part should not be in the loop, so we remove indentation
outRaster = CellStatistics(inRasters, "MEAN", "DATA")
# Save the output
outRaster.save("S:/Work/Risa/Trial_and_Error/output/AvgPrecip01.tif")
Looping through files one of the most useful and common tasks in GIS. Once you get this mastered you'll be set!
RPatarasuk
Thank you very much for your help. It still produces the same results. I am just wondering why you put
inRaster = []
Isn't it the same as
I have modified the code a bit and it takes the averages of all of the files. However, it does not exclude the file that has *.14. I changed these line
rasterFiles.append(filename) instead of inRasters
and
outRaster = CellStatistics(rasterFiles, "MEAN", "DATA") instead of inRasters
Here is the modified code:
import arcpy
# Input data source
arcpy.env.workspace = "S:/Work/Risa/Trial_Error/input"  # don't use spaces or special characters in path names
# Set output folder
OutputFolder = "S:/Work/Risa/Trial_Error/output/"
inRaster = []  # you need to do this outside of the loop
# Save the output
outRaster.save("S:/Work/Risa/Trial_Error/output/AvgPrecip18.tif")
#takes the average and including the file that ends with *.14
DarrenWiens2
Jook, you need the second list (inRasters = []) so that you have an empty place to put the rasters ending in "14.tif".
"rasterFiles = arcpy.ListRasters()" lists all of the rasters, then put the "14.tif" files into "inRasters". Then, calculate the mean of all of the rasters in "inRasters".
The way you have modified the code will produce the original list of all rasters, plus any file in "14.tif", so you'll have two copies of each "14.tif".
Finally, just to be clear you are not excluding the files ending in "14.tif", you are only using them (ie. you are excluding anything not ending in (14.tif")
RPatarasuk
Dear Darren,
Thank you very much for your reply. Maybe I said something wrong at the beginning. I want to include the files that ends with *.01 to *.12 but exclude *.14.
PhilMorefield
Dear Darren,
You can do that if you want. But as I pointed out earlier, the data you are working with already include the annual averages: the files ending in "14". If you're just going to average all months together, you can make things simpler and faster by just using the "14" files.
But, this is the change you should make to average 12 files from each year:
    if filename[-6:] in [str(x).zfill(2) + '.tif' for x in xrange(1, 13)]:
DarrenWiens2
Or, just to be lazy:
if not filename.endswith("*.14.tif"):
PhilMorefield
Touché.
Though you could run into trouble if some other raster is laying around in there. And also, the endswith method doesn't use asterisks as wildcards. It will evaluate the string literally and look for asterisks in the file name.
>>>filename = 'ppt_1970.14.tif'
>>>filename.endswith('14.tif')
True
>>>filename.endswith('*.14.tif')
False
