Find records with number/character that should not be there.
2037
6
04-21-2023 12:08 PM
CCWeedcontrol
I have a filed that I need to find records in a layer that have a number that should not be there. Not really sure on how to do this.
Rec field has length of 10. In the example below the first and fourth records has 0 in the 9th space (it could be a different digit) and some records will have an alph character in the 9th space, which is ok as long as it's an alph character. I would like to somehow mark the records.  Essentially, I need to find which records have a digit(skip if alph character is there) on the 9th space of the records. Hopefully this makes sense.
Rec
mark
12345678 0ok ( or 1)
22345108A0ok ( or 0)
6523148000Not ok ( or 0)
62315010 9Ok ( or 1)
6218921801Not ok ( or 0)
DavidPike
MVP Notable Contributor
Using Field Calculator in the attribute table https://pro.arcgis.com/en/pro-app/latest/help/data/tables/fundamentals-of-field-calculations.htm
or GP tool https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/calculate-field.htm
Calculate into the new field you've created for this i.e. 'mark'.
Expression type = Python 3
enter this in the box below "="
digitron(!tableName.rec or whatever your field is called - double click on the fields window to auto add the field!)
enter this in the 'Code Block' window:
def digitron(rec):
  try:
    if rec[8].isnumeric():
      return 'Not OK'
    else:
      return 'OK'
  except:
    return 'Some error'
validate then apply
CCWeedcontrol
This worked in Arcmap, but how can run it outside.
I tired the following but I get "Parameters are not valid." or with updatecursor?
import arcpy
inTable = "fc"
fieldName = "rec"
expression = "digitron(rec)"
codeblock = """
def digitron(rec):
  try:
      return 'Not OK'
    else:
      return 'OK'
  except:
    return 'Some error' """
arcpy.management.CalculateField(inTable, fieldName, expression, "PYTHON3", codeblock)
DavidPike
import arcpy
in_table = "fc"
field_names = ["rec", "mark?"]
with arcpy.da.UpdateCursor(in_table, field_names) as cursor:
    for row in cursor:
        try:
            if (row[0])[8].isnumeric():
                row[1] = 'Not OK'
            else :
                row[1] = 'OK'
        except:
            row[1] = 'Some error'
        cursor.updateRow(row)
CCWeedcontrol
oh I see, line 9  (row[0])[8].isnumeric.
Thanks for the help.
Jordan_Silver
Hello!  I think this function will do what your looking for:
def mark_records(records):
    result = []
    for rec in records:
        # Check if the 9th character (index 😎 is an alphabetic character
        if rec[8].isalpha() or rec[8].isspace():
            # Mark as ok
            result.append({"Rec": rec, "Mark": "ok"})
        elif rec[8].isdigit():
            # Mark as Not ok
            result.append({"Rec": rec, "Mark": "Not ok"})
        else:
            # If neither alphabetic nor digit nor space, mark as Invalid
            result.append({"Rec": rec, "Mark": "Invalid"})
    return result
CCWeedcontrol
I tried you function but I couldn't get it to work right.
pre-logic script code:
    result = []
    for rec in records:
        # Check if the 9th character (index  is an alphabetic character
            # Mark as ok
            # Mark as Not ok
        else:
    return result
Field = (!rec!)
