rows = arcpy.UpdateCursor("Junk1.dbf") fields = arcpy.ListFields("Junk1.dbf" ) #Create an empty list myList = [] i = 0 for row in rows: for field in fields: if field.name == 'ID': value = row.getValue(field.name) if value in myList: i += 1 row.TEST = i rows.updateRow(row) if value not in myList: myList.append(value)
import arcpy rows = arcpy.UpdateCursor("Filename") mylistarray = [] found = False for row in rows: value = row.getValue("ID") for x in mylistarray: if x[0] == value: found = True x[1] +=1 row.TEST = x[1] if not found: mylistarray.append([value,1]) row.TEST = 1 else: found = False rows.updateRow(row)
rows = arcpy.UpdateCursor("Junk1.dbf","","","","ID A") # sort by ID, ascending order #Create an empty list myList = [] i = 0 for row in rows: if i = 0: #first time around value = row.ID myList.append(value) i += 1 if row.ID != value: #if a new ID value = row.ID myList.append(value) i = 1 row.TEST = i rows.updateRow(row)
I usually use the approach of sorting by values, then comparing the previous value to the current value: rows = arcpy.UpdateCursor("Junk1.dbf","","","","ID A") # sort by ID, ascending order #Create an empty list myList = [] i = 0 for row in rows: if i = 0: #first time around value = row.ID myList.append(value) i += 1 if row.ID != value: #if a new ID value = row.ID myList.append(value) i = 1 row.TEST = i rows.updateRow(row)
rows = arcpy.UpdateCursor("Junk1.dbf","","","","ID A") # sort by ID, ascending order #Create an empty list myList = [] i = 0 for row in rows: if i == 0: #first time around value = row.ID myList.append(value) i += 1 print value, i if row.ID != value: #if a new ID value = row.ID myList.append(value) i = 1 row.TEST = i - 1 rows.updateRow(row)
rows = arcpy.UpdateCursor("Junk1.dbf","","","","ID A") # sort by ID, ascending order #Create an empty list myList = [] i = -1 for row in rows: if i == -1: #first time around value = row.ID myList.append(value) i += 1 print value, i if row.ID != value: #if a new ID value = row.ID myList.append(value) i = 0 row.TEST = i rows.updateRow(row)
any ideas on getting this run in the field calculator?
This is has been extremely helpful. Quick question as I am new to arcpy. If I want to mark ALL repeated IDs with a flag and not necessarily just the second, third, fourth occurrence, how might I accomplish this? For instance, if I had the following list of values:abcdeeWith the above scripts, I would geta-0b-0c-0d-0e-0e-1What I want is a-0b-0c-0d-0e-1e-1 or 2 (Doesn't matter as long as I can see that this value is not equal to zero).My goal is to flag the values that are duplicates, identify the value and then assign a new value to those records. If I split a polygon, for instance, I don't want to maintain the ID of the old one, I want to seek out the value and replace it with two new unique IDs.Thanks in advance.
rec=0 def autoIncrement(): global rec pStart = 1 #adjust start value to be the next number in the ID series pInterval = 1 #adjust interval value, if req'd if (rec == 0): rec = pStart else: rec = rec + pInterval return rec
# Import the arcpy module import arcpy pStart = 1 # adjust start value, if required pInterval = 1 # adjust interval value, if required # Initialize the sequence number dictionary and the Route ID variables seqDict = {} ID = -1 highest = 0 changed = False # Assign data and field list variables. # Customize these variable inputs for your specific data myData = r"C:\MyPath\MyData.shp" fields = ["ID"] # Step 1 - Use an search cursor to get counts of the unique ID numbers rows = arcpy.da.SearchCursor(myData, fields) for row in rows: if row[0] is None: ID = "Null" else: ID = row[0] if ID in seqDict: seqDict[ID] = seqDict[ID] + pInterval elif ID = 'Null': seqDict[ID] = 2 else: seqDict[ID] = pStart if highest < ID: highest = ID del row del rows # Step 2 - Use an update cursor to update all records with a count greater than 1 rows = arcpy.da.UpdateCursor(myData, fields) for row in rows: if row[0] is None: ID = "Null" else: ID = row[0] if seqDict[ID] > 1: highest = highest + pInterval row[0] = highest changed = True if changed: rows.updateRow(row) changed = False del row del rows
