FileNameInsert.py
4553
16
07-23-2014 12:40 AM
BenLeslie1
I downloaded this arcscript from here:   Filename Insert
It's an old script from 2006 and when I run it I get the following error:
File "C:\FileNameInsert.py", line 15, in <module>
  import win32com.client, sys, string, os
ImportError: No module named win32com.client
How do I modify this script so it works in 2014?
(what I hoping to achieve is to add a filename attribute to my shapefiles so that when I merge them together I can trace back to the originals)
BenLeslie1
I agree - but it's not clear how you've done that.
DanPatterson_Retired
again...not tested...try this
import arcpy
# Remember to change this to wherever your shapefiles are stored
arcpy.env.workspace = r"C:\temp2"
fcs = arcpy.ListFeatureClasses()
for fc in fcs:
   print fc
   # Create the new field
   arcpy.AddField_management (fc, "FILENAME", "text", "", "", "50")
   # Apply the filename to all entries
   arcpy.CalculateField_management (fc, "FILENAME", '"' + fc + '"')
    #print arcpy.GetMessages ()
There seems to be something with the try..except block
BenLeslie1
Thanks Dan - I'm a tiny step closer to being a python expert.
JohannesBierer
Haven't seen there was the solution 🙂
It's quite easy, you use the model builder and export to script ....
BenLeslie1
Sorry I didn't see you also corrected the script - I thought you were just saying your way of displaying the code in GeoNet was better.  It looks like a screenshot of Notepad++ but you can select the text?
I'm pretty new to Arc, I currently find ModelBuilder more confusing than code - I'm used to working with FME a lot so I want it to work like that, I find MB very unintuitive.
JohannesBierer
It's only a format option in GeoNet, you can define the code as python or other ....
Haven't used FME often, but don't u use there something similar to "model" geoprocessing tasks?
BenLeslie1
Actually I don't know why I mention it I think they are actually very different beasts and just because the flow diagram layout is similar I want to see ModelBuilder with my FME eyes.  And whereas FME is super flexible, user friendly and powerful, I have so far found modelbuilder to clunky, inflexible and unclear.
