Field Calculator with Python parser convert text to date
3294
7
09-20-2022 11:44 AM
2Quiker
I need to convert a text field "Year1" into a date filed (Year1) with just the year.
Field Year is a text field, with just a year date, "2015" and field Year1 is a date field.
from datetime import datetime
from datetime import time
import datetime as dt
from time import gmtime, strftime
def calcYear():
    fc = "Lyr"
    #testdate = '04/25/2015'
    with arcpy.da.UpdateCursor(fc,['Year','Year1']) as cursor:
        for row in cursor:
            if row[0] not in (""," ",None):
                d1 = datetime.strptime(datetime.strftime(row[0], "%Y"), "%Y")
                row[1] = d1.year
                cursor.updateRow(row)
I get the following error. I was thinking that line 11 was converting the text  into a day(year).
ERROR 000539: Traceback (most recent call last):
File "<expression>", line 1, in <module>
File "<string>", line 11, in calcYear
TypeError: descriptor 'strftime' requires a 'datetime.date' object but received a 'int'
Failed to execute (Calculate Field
by Anonymous User
Not applicable
The strftime() method returns a string representing date and time using date, time or datetime object. Try just strptime.
d1 = datetime.strptime(row[0], "%Y")
Edit to add:
This will return 2015-01-01 00:00:00
You can get the year with dot notation, but it is an int.
d1 = datetime.strptime(xd, "%Y").year
2Quiker
Thanks fro the replay.
Tried the following but nothing happens, no print, no error.
def calcYear():
    fc = "Lyr"
        for row in cursor:
                d1 = datetime.strptime(row[0],"%Y").year
                print(d1)  #"{}".formate(d1)
                row[1] = d1
by Anonymous User
Not applicable
You need to format it to match the input date format so if your date is mm/dd/YYYY, you'll use %m/%d/%Y:
d1 = datetime.strptime(row[0], "%m/%d/%Y").year
2Quiker
My apologizes for number of responses.
So field "Year" has just years, 2015,1997, 2022, etc and is a "text" field. It doesn't have month or days
When I replace the "%Y" with "%m/%d/%Y"
I get;
TypeError: strptime() argument 1 must be str, not int
Failed to execute
If i use the following
import datetime
def calcYear():
    fc = "Lyr"
        for row in cursor:
                d1 = datetime.datetime.strptime("{}".format(row[0]),"%Y").year
                return d1
                #formattedTime = datetime.datetime.strptime("{}".format(!Year!), "%Y")
                #row[1] = d1
                #cursor.updateRow(row)
I get Value = 1997
the Field "Year1" doesn't get updated
I tested this in python window
import arcpy
import datetime
#def calcYear():
fc = "Lyr"
    for row in cursor:
            print (d1)
            row[1] = d1
  I get the year printed
2022
2022
2022
2022
2022
2022
2022
2007
But the field "Year1" doesn't get populated/updated.
by Anonymous User
Not applicable
Spaced that you are doing this in a field calculator. You don't use a cursor in a field calculator because it will iterate over all features for each feature. Field Calculator has its own iterator so you do not have to set it.
Create the calculator on the target date field. Pass in the string field and return the value.
calcYear(!Year!)
import datetime
def calcYear(strYear):
    return datetime.datetime.strptime(strYear, '%Y')
2Quiker
Sorry for the delay, I got caught up.
I get the following with what you suggested.
File "<string>", line 3, in calcYear
I get the following If I do this .
WARNING 002858: Certain rows set to NULL due to error while evaluating python expression: File "<string>", line 3, in calcYear
calcYear(!Year!)
import datetime
    return datetime.datetime.strptime("{}".format(strYear), '%Y')
There is nulls in this field, how do I get past those nulls?
import datetime
    if (strYear == None):
        return 0
    else:
JoshuaBixby
MVP Esteemed Contributor
If strYear is None, why not just return None so the date has NULL since the year has NULL?
