***Field Calculator Help*** How to pad a string with periods to fit remaining field length
4085
13
05-01-2025 08:11 AM
JonM32
Hi Everyone,
I'm trying to create a nice road index for a map. One that looks like the screenshot below. However, I can't figure out how to create the index so that my road name listed has periods filling in the remaining space before the index cell is listed.
So far, I found some examples of python to use but nothing specific to how to enter it into the field calculator in ArcGIS Pro. The table shows my two fields, one with the street name, the other with the index cell it falls in on my map.
Any help is appreciated!
Cheers,
Jon
If this response helps or is the solution to your post, please consider marking it as a solution
TonyAlmeida
MVP Regular Contributor
You probably have nulls, spaces and number and text.
try this,
def format_index(name, index, total_length=5):  # Change to your data
    name = str(name).strip()  # String and strip whitespace
    index = str(index).strip()  # String and strip whitespace
    available_space = max(1, total_length - len(name) - len(index))
    dot_fill = '.' * available_space
    return f"{name}{dot_fill}{index}"
ClayDonaldsonSWCA
this is a perfect use case for f-strings. fstring.help: Python f-string guide
f"{!ALLROADNAM!:.<10}"
examples:
f"{'Done':.<12}" # Done.........
f"{123:.>8}" # .....123
f"{'Middle':.^10}" # ..Middle..
JonM32
@ClayDonaldsonSWCA Below is what I'm running into with the f-strings. Likely I'm entering it incorrectly, any idea whats going on?
Cheers,
Jon
AustinAverill
The expression is evaluating your field to include double quotes, and is therefore conflicting with your syntax. Change the code in your field calc to use single quotes instead of the double quotes will resolve the error:  f'{!ALLROADNAM!:.<10}'
TonyAlmeida
try,
format_index(!Field1Cal!, !IndexCell!)
def format_index(name, index, total_length=5): #change total_length
    name = name.strip()
    index = index.strip()
    dot_fill = '.' * max(1, total_length - len(name) - len(index))
JonM32
@TonyAlmeida I tried your suggestion and am running into the issue below. Any idea what is going on? I did change the first part before the code block to match my field names.
Cheers,
Jon
TonyAlmeida
try this,
JonM32
@TonyAlmeida I'm so close! It was able to run in the field calculator - but now I'd like to get dots to even out so the index values are all aligned together. Similar to the first screenshot above. Below is what I have, is there a way to align the index values?
I really appreciate your help!
Cheers,
Jon
TonyAlmeida
try,
.ljust(total_length) # this should make sure the output string is exactly 50 characters wide
def format_index(name, index, total_length=50):
    name = str(name).strip() if name else "Unknown"
    index = str(index).strip() if index else "--"
    return f"{name}{dot_fill}{index}".ljust(total_length)
JonM32
@TonyAlmeida  Unless I entered it incorrectly, I keep having errors pop up when trying to run it.
Cheers,
Jon
