FIDSet method returns empty if layer object is in a group layer
1482
07-31-2024 07:55 AM
Glasnoct
I was wondering if someone has an answer as to why the arcpy.Describe(lyr).FIDSet method returns an empty string if the lyr object happens to reside in a group layer as opposed to the root of the map contents?
given a layer named "STREETS," if the layer is in the root, the following correctly returns the selected objectIDs
lyr = mp.listLayers('STREETS')[0]
returns '78878180; 78879544; 78930438'
if 'STREETS' is in a group layer 'BaseMap' the lyr is returned fine but the FIDSet method returns an empty string. To successfully return the selected objects I need to pass lyr.longName. Why does the selection not seem to exist for the object the same way the layer's location string does?
DanPatterson
MVP Esteemed Contributor
Layer properties—ArcGIS Pro | Documentation
There are differences in arcpy.Describe and arcpy.da.Describe as noted in the help topic.  Is there a reason that you are using the former?
... sort of retired...
Glasnoct
Just habit; likely have been running with the former due to its use in examples I found at one point.
the difference between the two in the documentation just says one returns a string and the other a list and both result in the same discrepancy in the FIDset value. I looked through the documentation some more but see nowhere that explains why the FIDSet disappears once the layer is moved into a group layer even if the exact same layer object is supplied to Describe.
DanPatterson
I don't work with these types of situations, but the isGroupLayer and longName seem to be the way as you describe as in the Discussion section here
Layer—ArcGIS Pro | Documentation
