Feature class name wildcard
8269
10
12-21-2017 10:41 AM
CCWeedcontrol
I have a feature class table that i need to export to excel, the feature class will be created weekly. The problem i am having is that on creation the feature class gets the date added to the end of the feature class name and i am trying to access with a wildcard because the date will change based on when the feature class gets created. How can i get the feature class with a wildcard?
import arcpy
workspace = "Database Servers\GIS.gds\GISSERVER1 (VERSION:dbo.DEFAULT)"
arcpy.env.workspace = workspace
lyrs = ['Hyrdo_FINAL_ALL_*']
for fc in arcpy.ListFeatureClasses():
    for lyr in lyrs:
        if fc.startswith(lyr):
            print 'lyr'
lyr = "Hyrdo_FINAL_ALL_*" #Database Servers\GIS.gds\GISSERVER1 (VERSION:dbo.DEFAULT)\Hyrdo_FINAL_ALL_121817
arcpy.MakeFeatureLayer_management(lyr, "In_memory\lyr1")
arcpy.TableSelect_analysis("In_memory\lyr1","C:/Temp/Export_Output.xls", "")
print 'done'
CCWeedcontrol
I was able to get it to work by removing the feature_dataset [0] and making the workspace a "database connection" not a direct connection.
import arcpy
from arcpy import env
arcpy.env.workspace = "Database Connections\GISSERVER1 (VERSION:dbo.DEFAULT)"
lyr = arcpy.ListFeatureClasses ("Hydro_FINAL_ALL_*")#Database Servers\GIS.gds\GISSERVER1 (VERSION:dbo.DEFAULT)\Hyrdo_FINAL_ALL_121817
for fc in lyr:
    arcpy.MakeFeatureLayer_management(fc, "In_memory\lyr1")
    #arcpy.FeatureClassToFeatureClass_conversion("In_memory\lyr1","C:\Temp","Export.shp")
print 'done'
