FATAL ERROR (ICLOSE)
1482
03-30-2011 01:26 AM
AndrewHardy
Has anyone ever come across a python error looking like this...
Attempting to close channel 2, which isn't open
I am extracting zonal stats as a table for multiple sets of two raster datasets. These tables are joined and the joined table is outputted as a csv. Numpy is then used to calculate the correlation coefficent which is then written to a text file.
It works fine for the first two set of files then comes up with the above error message. I found a link to a known error with ArcWorkstation (http://resources.arcgis.com/content/kbase?fa=articleShow&d=11798) but not sure whether it is relevant here
I am running ArcGIS 9.3 - code attached if interested.
Any thoughts?
DarrylKlassen
Has anyone resolved this issue?  I am getting the same error message!
Darryl Klassen
GIS Technician
DavidRheinheimer
For other GIS Googlers out there:
I just encountered and resolved this issue, so thought I'd post a reply. This issue also arose when I was using ZonalStatisticsAsTable() in python. Furthermore, I was also creating a SearchCursor from the new zonal stats table and working with the cursor. I was able to resolve the problem by properly deleting the cursor after each use (and there are several "proper" ways to delete a cursor--e.g., a simple "del cursor" works to resolve the problem).
I hope this helps!
David
RyanHill1
I encountered this when working with Search and Insert cursors. I had a script which was working fine, all tables being accessed and written to within a File Geodatabase. I made some script changes, in which tables were now being written into a simple directory folder. Absent mindedly, I initially did not change table names explicitly with ".dbf" in the script, so within the folder they were written as default INFO tables, and the problem surfaced. I created a new FGDB in which to write the tables as default dBASE and the problem disappeared. As per the above response, properly deleting cursor resources is also probably important.
-Ryan
