Failed to execute (ExtractByMask)
2459
03-12-2012 04:38 PM
haiyanwei
Dear Forum,
I found a loop example here from the forum and modified for my case. Thanks for the previous Q/As.
what I am trying to do is:
1. read a list of ascii files
2. convert them to raster
3. clip raster file by a boundary mask
4. convert the clipped raster to polygon
I got an error message for 'extractbymask':
ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000860: Input raster or feature mask data: is not the type of Composite Geodataset, or does not exist.
Failed to execute (ExtractByMask).
here is the code:
# convertions_loop.py
# Created on: Mon Mar 12 2012 04:31:41 PM
#   (generated by ArcGIS/ModelBuilder)
# Import system modules
import sys, string, os, arcgisscripting
# Create the Geoprocessor object
gp = arcgisscripting.create()
# Check out any necessary licenses
gp.CheckOutExtension("spatial")
# Load required toolboxes...
gp.AddToolbox("C:/Program Files/ArcGIS/ArcToolbox/Toolboxes/Spatial Analyst Tools.tbx")
gp.AddToolbox("C:/Program Files/ArcGIS/ArcToolbox/Toolboxes/Conversion Tools.tbx")
# Set local variables
InAsciiFile = None
inDir = r"C://a//asc_annual_PDSI"
OutRaster = "C://a//raster_annual"
SRER_bound="C://Spatial//shape_files//bounds.shp"
OutClip="C://a//raster_annual_clip"
OutPolygon="C://a//polygon_annual"
for InAsciiFile in os.listdir(inDir):
    if InAsciiFile.rsplit(".")[-1] == "asc":
        print InAsciiFile
# Process: ASCIIToRaster_conversion
        outR= os.path.join(OutRaster,InAsciiFile.rsplit(".")[0])
        gp.ASCIIToRaster_conversion(os.path.join(inDir,InAsciiFile), outR, "INTEGER")
# Process: Extract by Mask...
        outC=os.path.join(OutClip,InAsciiFile.rsplit(".")[0])
        gp.ExtractByMask_sa(outR, SRER_bound, outC)
# Process: Raster to Polygon...
        outP=os.path.join(OutPolygon,InAsciiFile.rsplit(".")[0])
        gp.RasterToPolygon_conversion(outC,outP, "NO_SIMPLIFY", "VALUE")
I tried to use:
SRER_bound="C://Spatial//shape_files//bounds"
but got the same error
Could anyone please help? Thanks.
MathewCoyle
Honored Contributor
It may have difficulty reading your path formats for some tools.
Valid Python paths should be
r"C:\GISpath\somefile.ext"
"C:/GISpath/somefile.ext"
"C:\\GISpath\\somefile.ext"
Also I would suggest printing the values of your variables just before the tool to make sure there isn't something going wrong there.
haiyanwei
Thank you mzcoyle
It is working now. It should be:
SRER_bound="C://Spatial//shape_files//bounds//bounds.shp"
I got another error at the third step"Raster to Polygon...", then I changed the path as you suggested, it worked. Thanks!!
