Extract by Mask Not Saving to Correct Location
949
10-30-2013 06:00 PM
RachelAlbritton
My script has been working fine and it's suddenly stopped. Its getting hung up on the Extract by Mask task, and its failing because its trying to save the output to a location other then what I've specified. Why would this be happening? I've even restarted my computer and I'm still getting the same problem.
import arcpy
#set workspaces
arcpy.env.workspace = "C:\\ArcGIS\\SurfCityData\\Data" #arcpy.GetParameterAsText(0)
outputWorkspace = "C:\\ArcGIS\\SurfCityData\\Data\\OutputData" #arcpy.GetParameterAsText(1)
arcpy.env.overwriteOutput = True
#Variables
ObsPts = "C:\\ArcGIS\\SurfCityData\\Data\\Projected_Data\\Test_Points.shp" #arcpy.GetParameterAsText(2)
footprint =  "C:\\ArcGIS\\SurfCityData\\Data\\Projected_Data\\Building_Footprints.shp" #arcpy.GetParameterAsText(3)
Elevation = "C:\\ArcGIS\\SurfCityData\\Data\\Projected_Data\\new_2010 "#arcpy.GetParameterAsText(4)
BareElevation = "C:\\ArcGIS\\SurfCityData\\Data\\Projected_Data\\baregrnd" #arcpy.GetParameterAsText(5)
FOLDER = outputWorkspace+"/Intermediate_Files_1_"+Year
PointsFL = outName(ObsPts,"_Lyr")
footprintFL = outName(footprint,"_Lyr")
arcpy.MakeFeatureLayer_management(ObsPts, LAYER)
arcpy.MakeFeatureLayer_management(footprint,footprintFL)
try:
            FID = "FID=%s" % (points)
            #Get bare earth elevation of parcel
            arcpy.SelectLayerByAttribute_management(LAYER,"NEW_SELECTION",FID)
            arcpy.SelectLayerByLocation_management(footprintFL,"INTERSECT",LAYER)
            outExtractByMask = ExtractByMask(BareElevation,footprintFL)
            outExtractByMask.save(FOLDER+"/tempfp_"+str(FID)[4:])
except:
            print arcpy.GetMessages()
ERROR MESSAGE:
ERROR 000875: Output raster: C:\ArcGIS\SurfCityData\Data\OutputData/Intermediate_Files_1_2010\Extract_bare1's workspace is an invalid output workspace.
JakeSkinner
Esri Esteemed Contributor
Hi Rachel,
Try changing the line:
to:
outExtractByMask.save(FOLDER+"\\tempfp_"+str(FID)[4:])
RachelAlbritton
Thanks for the suggestion. The entire script just keeps crashing now - both inside Arcmap and if i try to run the stand alone script.
Something that just occured to me - I wrote the script in python 2.7, ArcMap 10.1 but I'm currently trying to execute it with python 2.6.5/ArcMap 10. Could this be causing it to crash? Could moving the script back and forth between version corrupt the file in any way?
