Extract by Attributes error with extract.save
3961
6
04-11-2012 12:04 PM
AnneRiddle
On the following code block (specifically, the last line), IDLE throws this error:
ERROR 010093: Output raster format UNKNOWN is unsupported.
for raster in arcpy.ListRasters():
    outpoint = workspace + raster + "af"
    extract = arcpy.sa.ExtractByAttributes (raster, " VALUE = 6 OR VALUE = 8")
    extract.save (outpoint)
I feel like it shouldn't be necessary to specify a format since the output is saving into a geodatabase. Also, is there better documentation on extract.save somewhere? I've found very little on it and am just imitating the syntax example used on the Extract by Attributes tool page.
MarcinGasior
Based on your script I created this one:
import arcpy
arcpy.CheckOutExtension("Spatial")
workspace = "C:/tmp/Testing.gdb"
arcpy.env.workspace = workspace
try:
        outpoint = workspace + "/" + raster + "af"
        extract = arcpy.sa.ExtractByAttributes(raster, "VALUE = 6 OR VALUE = 8")
        extract.save(outpoint)
except:
    arcpy.GetMessages()
Works.
AnneRiddle
This was basically the same as the script I had, with the addition of the backslash. Mine looks like this:
arcpy.env.workspace = r"S:\FIRE\86to92.gdb"
workspace = arcpy.env.workspace
outtable = r"S:\FIRE\73to80.gdb\y86to92"
However, now I am getting this error message:
  File "S:\FIRE\gdb.py", line 33, in <module>
  File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\sa\Functions.py", line 1117, in ExtractByAttributes
    where_clause)
  File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\sa\Utils.py", line 47, in swapper
    result = wrapper(*args, **kwargs)
  File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\sa\Functions.py", line 1113, in wrapper
    out_raster)
  File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\geoprocessing\_base.py", line 474, in <lambda>
    return lambda *args: val(*gp_fixargs(args))
ExecuteError: ERROR 999999: Error executing function.
Access denied
Access denied [GDB_Items]
No spatial reference exists.
ERROR 010302: Unable to create the output raster: S:\FIRE\86to92.gdb\Extract_u8001
ERROR 010067: Error in executing grid expression.
Failed to execute (ExtractByAttributes).
ERROR 010302 suggests that I don't have write permission or don't have enough space available. I checked and both of these are OK.
toddsams
I am getting the same error as the original post on this thread (ERROR 010093). I tried changing my os.sep to "/" but still get the error. My code is below, the error occurs on the FdrOut.save line:
for HUC in HUCs:
    print HUC
    try:
        FDRpath = Main + os.sep + "fdr"
        FACpath = Main + os.sep + "fac"
        print FDRpath
        print FACpath
        # Execute ExtractByMask
        FdrOut = ExtractByMask(MainFdr, HUC)
        # Save the output
        FdrOut.save(FDRpath + "/" + "fdr_" + HUC)
        print "fdr finished"
    except:
        print "error_" + HUC
        continue
MarcinGasior
I believe you shold use "\" instead of "/" in this line.
BTW, os module prowides very convenient method for constructing pathes - join. In your case it will be:
outRaster = os.path.join(FDRpath, "fdr_" + "HUC")
FdrOut.save(outRaster)
The same way you can construct FDRpath and FACpath variables.
curtvprice
A few things to keep in mind:
  • Although Spatial Analyst tools now do direct read/write of many formats, grid (folder workspace) is usually still the best choice.
  • The workspace and scratchWorkspace should be set to the same folder for best performance.
  • Grid format is limited to 13-characters, alphanumeric + "_", starting with a letter.
  • Workspace, feature class, table, and field names should never begin with a number.
ThomasLaxson
This error (010093) often occurs when trying to create an improperly named raster file. For GRIDs, the naming restrictions include:
...a grid should not be named with spaces or any other special characters in its name. A multiple-band grid cannot have more than 9 characters in its file name, and a single-band raster dataset cannot have more than 13 characters.
Todd, this probably applies in your case, if you're using HUC 12s; the appending of your four characters ('fdr_') puts you over the 13 character limit.
See ESRI's help page on GRIDs for more info.
