extract a variable in netCDF file
1633
12-20-2012 10:26 AM
GualbertoHernández_Juárez
Anyone have a script to extract a variable in NetCDF file?
I hope you can help me.
thanks
Gualberto
markdenil
MakeNetCDFFeatureLayer_m is the key tool. It will convert the netCDF to points.
There are lots of arguments to the tool, making it pretty flexible.
I used it (for a 9.3 geoprocessor) thus:
netCDF = r"c:\thePath\theNetCDFFile"
outLayer = "Xout_Layer"
gp.MakeNetCDFFeatureLayer_md(netCDF, "uvel;vvel",
                                "lon", "lat", outLayer,
                                "lat;lon", "", "", "", "BY_VALUE")
This extracts the lat/long located cell centers as lat/long points with uvel and vvel attributes to a layer.
with arcpy, use python lists instead of semicolon delimited strings for the variables and dimension lists.
Hi Mark,
My netCDF file has forecast variables: wind, rh, SPLV, etc and they all have the time dimension.
I just need the variable dimension PSLV but with time, he knows how to go?
Thank you very much for your reply.
markdenil
If you want a seperate feature for each time step, include time as a row dimension.
mdenil,
I did what you said and it worked, but I need to do this for each grid point of my netcdf file is 150 x 200, so are 30,000 points.
Can you suggest any procedure to get them?
Thank you very much for your help!.
Gualberto
