Extend line to specific distance or a line
25637
13
01-07-2016 12:35 AM
MonirRahman
I want to extend my polyline to a given distance. How can I do this. I have attached image to clear my specification.
I am using .net in arcmap . I am also using python
Thanks.
Tags (3)
LukeSturtevant
Perhaps you are looking for something like this? arcgis 10.1 - A tool or way to Extend line by specified distance? - Geographic Information Systems S...
I've put the script into a working script tool attached to this thread for you to try.
DanPatterson_Retired
I agree with Reza, you need to figure out what you want to use first
arcpy - Extend line to specific distance or a line - Geographic Information Systems Stack Exchange
LukeSturtevant
ArthurCrawford
Useful to extend a line both ways by using with flip tool.
Deborah_Priss
Sorry for bothering you again with this issue. The Extend Lines script worked perfect for me, thank you @LukeSturtevant  for that! I need to extend the lines in both directions but the flip tool doesn't seem to work. The lines are still extended into the same direction as before. Any ideas what the problem might be?
Thank you!
lsturtevant
Hi @Deborah_Priss. I've attached an updated version of this tool that might help with extending in both directions. Make sure that you run the tool in an open ArcMap document or ArcGIS Pro project and not through ArcCatalog. As a check, I would suggest you run the Feature Vertices To Point tool to get both end and start points for your lines before running this tool and then do a manual check to see if the tool is behaving the way you are expecting.
EDITED: I've replaced the attached zip file to comply with ArcMap script tool parameter syntax. Deborah has confirmed that it works in ArcMap now. There is also an additional option to extend in both directions.
Deborah_Priss
Thank you again! However, I cannot run it: Error - value is not member of Feet | Meter. I've never really used Python and am not familiar with arcpy, so I cannot adjust the script myself - Sorry! My .shp is in a projected coordinate system with meters as linear unit.
EVEA0
Hi Isturtevant,
Thank you for this solution. I want to include your tool in my model builder process flow, and therefore need an output variable so I can use its outputs in the process. Do you have any tips for how to achieve this?
lsturtevant
Hello @EVEA0. To add an output variable for a model builder process you can edit the Extend Line script tool parameters to include a "Derived" output like so:
Britta_Schroeder
Thanks, Luke Sturtevant‌ for creating a toolbox for this script, this tool seems to be the solution I'm looking for. Unfortunately, I receive an error with the following information when I try to use the script with a feature class in a file geodatabase in ArcMap 10.6:
File "C:\Users\bschroeder\Desktop\Extend Lines.tbx\Extend Lines.tbx#extendLines2.py", line 54, in <module>
SystemError: error return without exception set
Any thoughts on what may be causing the error Arthur Crawford‌?
