Exporting chart in arcopy Errno 13 permissions error
2267
01-25-2023 03:57 AM
ChelseaVSmith
Hi I'm using ArcPro 3.0. and using arcpy to export a chart following on from a script used to produce scores at the start of the script I have set the environment. However, when I try to export chart to SVG I get a Permissions error that I can't find any guidance on. Any help much appreciated.
c = arcpy.Chart('bar_final_scores')
c.type = 'bar'
c.title = "Final HBRA Scores for AU"
c.xAxis.field = 'Criteria'
c.xAxis.title= "Criteria"
c.yAxis.field = 'Score'
c.yAxis.title = "Score"
c.bar.aggregation = ''
c.dataSource = 'AUFinal'
c.exportToSVG('bar_final_scores.svg')
  File "<string>", line 12, in <module>
  File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\charts.py", line 448, in exportToSVG
    with _codecs.open(path, "w", "utf-8") as f_svg:
  File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\codecs.py", line 905, in open
    file = builtins.open(filename, mode, buffering)
PermissionError: [Errno 13] Permission denied: 'bar_final_scores.svg'
Best,
Chelsea
Tags (4)
DanPatterson
MVP Esteemed Contributor
try providing a full path to the output svg
... sort of retired...
DanPatterson
ChelseaVSmith
Thank you that worked!
Do you know how I can export a chart to png instead of svg file?
ChristopherAllen
Hi @ChelseaVSmith ,
Unfortunately, it's currently only possible to export a chart in SVG format from Python (though you can also export in PNG or JPG formats from the UI). We hope to add Python support for PNG and JPG in the near term.
Chris
