Export Pro Metadata XML with Python
2379
03-27-2023 12:37 PM
by Anonymous User
Not applicable
Hi I'm trying to access an ArcGIS Pro item's metadata XML using python and was wondering if anyone could help. I'm using the exportMetadata function in the documentation ((https://pro.arcgis.com/en/pro-app/latest/arcpy/metadata/metadata-class.htm)) but when I open the XML that I stored, it looks like the code piece below. It's the metadata of when I ran my python script instead of the metadata of the item in Pro. Has anyone ran into a similar issue or know the solution?
<?xml version="1.0"?>
<metadata xml:lang="en"><Esri><CreaDate>20230327</CreaDate><CreaTime>11230800</CreaTime><ArcGISFormat>1.0</ArcGISFormat><SyncOnce>TRUE</SyncOnce></Esri></metadata>
Here's what my code looks like:
item_metadata = md.Metadata(path)
item_metadata.exportMetadata(outputXMLPath)
 Thank you!
Tags (4)
by Anonymous User
Not applicable
What specific item are you trying to get the metadata for?  Seeing more of your code could help with an answer.
