Export layout to jpeg
2231
01-29-2021 05:09 AM
Official4
I want to export my layout to jpeg using arcpy but I was getting this error "Runtime error
File "<string>", line 22, in <module>
File "c:\program files (x86)\arcgis\desktop10.8\arcpy\arcpy\utils.py", line 182, in fn_
return fn(*args, **kw)
File "c:\program files (x86)\arcgis\desktop10.8\arcpy\arcpy\mapping.py", line 1026, in ExportToJPEG
layout.exportToJPEG(*args)
File "c:\program files (x86)\arcgis\desktop10.8\arcpy\arcpy\arcobjects\mixins.py", line 608, in exportToJPEG
return self._arc_object.exportToJPEG(*args)
AttributeError: PageLayoutObject: Error in executing ExportToJPEG". I change the path to different folder and it worked. I am now getting the same errors again. What could be the cause and any workaround?
by Anonymous User
Not applicable
If you share your code, we can provide better help.
Official4
outpath = 'C:\Users\JOE\Desktop\maps\DUNKWA A/' + str(row.SOCIETY) + str(row.FID) + '.jpg'
arcpy.mapping.ExportToJPEG(mxd,outpath)
by Anonymous User
Not applicable
Well,  putting that string into python and trying to print it raises an unicode error in python 3.6.  It printed when I treated it as a raw string and used formatting.  Used some dummy values since I don't know what your row.society or row.FID is.
print(r'C:\Users\JOE\Desktop\maps\DUNKWA A\{}{}.jpg'.format(str('Geo'), str('net')))
print(r'C:\Users\JOE\Desktop\maps\DUNKWA A\{}{}.jpg'.format(str(row.SOCIETY), str(row.FID)))
prints:  C:\Users\JOE\Desktop\maps\DUNKWA A\Geonet.jpg
Tomasz_Tarchalski
When using arcpy and python, make sure that you add r'' ('raw string') before the path. so for example:
outputpath = r'C:\Temp\MyFolder'
You coul also write like this:
outputpath = "C:\\Temp\\MyFolder"
or
outputpath = 'C:/Temp/MyFolder'
