Export features to new shapefile
2210
01-23-2013 04:58 AM
ChrisBrannin
I am trying to write a small script to export each feature in a featureclass to a new shapefile. When I run it, all I see is red (errors). Any help would be greatly appreciated.
import arcpy from arcpy import analysis, env   fc = arcpy.GetParameterAsText(0) field = arcpy.GetParameterAsText(1) env.workspace = arcpy.GetParameterAsText(2)   with arcpy.da.SearchCursor(fc, (field,)) as cursor:     for row in cursor:         arcpy.MakeFeatureLayer_management(field)
by Anonymous User
Not applicable
Sorry, my test was on strings.  I did not include functionality for other types.  Try this:
import arcpy from os import path as p arcpy.overwriteOutput = True   fc = r'F:\shape_clean_python\rioDej_fav.shp' field = 'FID' outws = r'F:\shape_clean_python\exports'   valList = [] with arcpy.da.SearchCursor(fc,[field]) as rows:     for row in rows:         value = row[0]         if value not in valList:             valList.append(value)    for val in valList:         for fld in arcpy.ListFields(fc):             if fld.name == field:                 if fld.type == 'String':                     query = '"{0}" = \'{1}\''.format(field,val)                 else:                     query = '"{0}" = {1}'.format(field,val)              output = p.join(outws,str(val).replace(' ','_'))         desc = arcpy.Describe(outws)         if desc.workspaceType == 'FileSystem':             output += '.shp'         if arcpy.Exists(output):             arcpy.Delete_management(output)         arcpy.Select_analysis(fc, output, query)         print 'Created "%s"' %p.basename(output)
by Anonymous User
Not applicable
Something like this should work.  I changed the env workspace to just a user specified output workspace.  I also chose to name the ouput feature class to the name of the value from the field.
import arcpy
outws = arcpy.GetParameterAsText(2)
valList = []
    for row in rows:
        value = row[0]
for val in valList:
    output = p.join(outws,val.replace(' ','_'))
        output += '.shp'
EDIT: I changed the code to match 10.1 with da cursors.  It also does a check on the workspace type to add the '.shp' if necessary.
ChrisBrannin
Sorry for the bad question here but. I am seeing this error:
AttributeError: 'int' object has no attribute 'replace'
I am not familiar with val.replace(). Thanks again.
by Anonymous User
Not applicable
by Anonymous User
Not applicable
Actually this is better so that the field type test is not in the loop:
import arcpy
field = 'FID'
valList = []
    for row in rows:
        value = row[0]
                x = 'str'
            else:
                x = 'other'
    for val in valList:
        if x == 'str':
        else:
            output += '.shp'
ChrisBrannin
Thank you, this worked like a charm! Greatly appreciated!
