Export Attributes from Arcmap without Geometry fields
5665
14
11-01-2019 09:57 AM
2Quiker
I need to export attributes from a certain layer in Arcmap but without the OID & Geometry fields to excel.
I've tried the following bet i am getting error ("AttributeError: DescribeData: Method areaFieldName does not exist") on line 15. I would appreciate any help with the code, thanks.
import arcpy
import os
mxd = arcpy.mapping.MapDocument("CURRENT")
df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0]
lyr = arcpy.mapping.ListLayers(mxd, "Notified")[0]
arcpy.env.workspace = os.path.dirname(mxd.filePath)
wp = os.path.dirname(mxd.filePath)
fc = "Notified"
desc = arcpy.Describe(fc)
f = desc.fields
fields = [f.name for f in f if f.name != desc.OIDFieldName and f.type != 'Geometry' and f.name != desc.areaFieldName and f.name != desc.lengthFieldName]
for fld in fields:
    fields.remove(fields)
arcpy.MakeQueryTable_management(fc, "tmp_table", "NO_KEY_FIELD")‍‍‍‍‍‍‍‍
arcpy.TableToExcel_conversion("tmp_table", Notified_xls) ‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
2Quiker
Jake,
I get error on in TableToExcel     raise e ExecuteError: ERROR 000814: Invalid file type Failed to execute (TableToExcel) with ".xlsx"
If i change the output to ".xls" get "RuntimeError: Cannot find field ''.
I need this to run in side python in Arcmap not in a stand alone script. This will be made into a tool script.
import arcpy
lyr = arcpy.mapping.ListLayers(mxd, "Export_Output")[0]
# Create a fieldinfo object
fieldInfo = arcpy.FieldInfo()
# Fields to Hide
hiddenFields = ('FID', 'Shape', 'OBJECTID', 'Shape_Leng', 'Shape_Area')
# Get the fields from the input
fields= arcpy.ListFields(lyr)
for field in fields:
    if field.name not in hiddenFields:
       fieldInfo.addField(field.name, field.name, "VISIBLE", "")
    else:
       fieldInfo.addField(field.name, field.name, "HIDDEN", "")
# Create table view
arcpy.MakeTableView_management(lyr, "Notif_view", "", "", fieldInfo)
# Export to Excel
arcpy.conversion.TableToExcel("Notif_view", r"C:\temp\Notif_view.xlsx")
arcpy.RefreshActiveView()
arcpy.RefreshTOC()‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
JoeBorgione
I shy away from field mapping as well. If you don't mind a hack, you could do a table to excel and then open your new excel worksheet and just delete the fields you don't want.....
2Quiker
Ya I agree i could just open the excel spreadsheet and delete them  if i were only doing it so often. I usually run this process about 10 times a week. So i was trying to make it as stream lined as possible.
DanPatterson_Retired
Has anyone tried the editable property?  aka, only export those that are editable in conjunction with some of the others.
editable
(Read and Write)
The editable state: True if the field is editable.
Boolean
JohannesBierer
A working possibility could be to convert to numpy array, then use pandas to convert the array to excel?
import arcpy
import pandas as pd
inTable = r"yourpath\Export_Output.shp"
outTable1 = r"yourpath\export.xls"
fieldNames = ["OBJECTID", "PARCEL_NO", "OwnerName", "Address", "City", "State", "ZipCode"]
arr = arcpy.da.FeatureClassToNumPyArray(inTable, fieldNames)
df = pd.DataFrame(arr)
df1 = df.to_excel(outTable1, index=False)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
