Export a report to PDF using Python
6478
9
04-16-2019 02:01 AM
DmitryKirianov
Hi all,
I'm trying to export a report to PDF via report.exportToPDF (as described into help section). The script works fine but the created PDF's size is too big (~50 Mb) because all the pages of the report are rasterized.. Comparing with the file created via UI (ArcGIS Pro -> Report -> Share as PDF) which is about ~600 kb.. cause this file is in "vector" normal PDF format (except for small pictures with logo).
So, the question: is it possible to export report into PDF via arcpy the same way like from ArcGIS Pro UI?
I'm using latest version of ArcGIS Pro 2.3.2. and default python 3 environment.
Example of the code:
import arcpy, datetime, os
      # Set parameters for the main report & create PDF
aprx = arcpy.mp.ArcGISProject(r"c:\NGM_GIS\NG_Projects_all\NG_Projects_all.aprx")
report = aprx.listReports("TenementExtract Report TEST A3")[0]
outPDF_report = r"c:\NGM_GIS\NG_Projects_all\ReportTEST\NG Tenement Report A3.pdf"
if os.path.exists(outPDF_report): os.remove(outPDF_report)
report.exportToPDF(outPDF_report)
print("PDF report is created!")
I've already tried to insert different parameters into report.exportToPDF e.g.
1) compress_vector_graphics=True,
2) embed_fonts=True
3) image_compression = "NONE"
- always receive the same result...
P.S.  in contrast exportToPDF works perfect with Layouts.
DanPatterson_Retired
Did you try setting 'embed_fonts' to false?  I am wondering if the defaults in
Report—ArcPy | ArcGIS Desktop
are the same as used in the UI
DmitryKirianov
Dan,
yes, i've tried switch "embed_fonts" to false - nothing changed..
While it's not clear why this parameter can influence and also i would like to have final PDF with all the fonts embed.
BTW, attached are the 2 printscreens showing the properties for the 2 different PDFs. It's obvious that they've been produced by different applications but i can't see any other differences.. and as i mentioned above exportToPDF (python console...) works fine for the layouts.
Dmitry... one person might know...
Kory Kramer‌ are the print engines the same in Pro from the UI vs script?
KoryKramer
Esri Esteemed Contributor
Forwarding this question to Jeremy Wright
JeremyWright
Let me correspond with the product team responsible for the reports functionality and get back to you all.
DonMorrison1
Jeremy Wright , did you ever get an answer to this?  I'm about to recommend that we use the ArcGIS Pro reporting function for one of our projects but this might be a deal breaker since we will be generating a large number of documents. I'd much rather find out now than after we have invested a lot of time on it. Thanks
DanPatterson
That was a few versions ago with no report back.
If you have a test report, either try the tool
Export Report To PDF (Data Management)—ArcGIS Pro | Documentation
or through arcpy
Report—ArcGIS Pro | Documentation
or you could look back in time to see if it was addressed
Release notes for ArcGIS Pro 2.6—ArcGIS Pro | Documentation
plus previous versions
... sort of retired...
DmitryKirianov
Hi all,
It seems they have fixed the issue many months ago... i'm sure even in Pro 2.5 (or probably earlier) it worked fine and at the moment i'm using latest Pro 2.6.1 and it's ok.
DonMorrison1
I think you are correct.  I'm not seeing any problem - at least with the PDFs that I'm generating.
