Hello everyone,
I am working on arcmap 10.3.1 and python 2.7.8. I need to determine how much time arcpy needed to finish a specific task (add layer) . I'm using this code:
import arcpy,os,sys,string,datetime,timeit
import arcpy.mapping
from arcpy import env
env.workspace = r"C:\Project"
Layer1 = arcpy.mapping.Layer(r"C:\Project\layers\atikot.lyr")
counter = 0
for mxd in arcpy.ListFiles("*.mxd"):
print (mxd)
mapdoc = arcpy.mapping.MapDocument(r"C:\Project\\" + mxd)
df = arcpy.mapping.ListDataFrames(mapdoc, "Layers")[0]
arcpy.mapping.AddLayer(df ,Layer1, "TOP")
print ('AddLayer')
mapdoc.save()
counter = counter + 1
del mxd
print (counter)
print str(datetime.datetime.now().date())
print time.clock()When i run it i get:
>>> Project 2.mxd AddLayer Project.mxd AddLayer soil.mxd AddLayer soil_20008.mxd AddLayer ta34b_4.mxd AddLayer wells.mxd AddLayer 6 2015-03-18 3.20723655198e-07 >>>
I have been unable to get execution times for the processes. when i measured this process with stopper -i got 9.6 second in real time
but in the code the score is 3.207. I dont know if 3.2 is seconds -and if it is that mean this time isn't right.
Any help would be great
practice with your stop watch before you use the time function
copy and paste these in an interactive editor session
>>> import datetime >>> now = datetime.datetime.now() # wait a bit, then paste the next line >>> later = datetime.datetime.now() >>> # ... your code stuff here or nothing ... >>> elapsed = later - now >>> print elapsed 0:00:04.416000 >>>
And for extra clarity... just substitute the nap_time line with your code block
# time_timeit_sleep_demo.py # [email protected] # import time import datetime now = datetime.datetime.now() # nap_time = time.sleep(5) # sleep time in seconds... change to test # later = datetime.datetime.now() elapsed = later - now print('Nap time was... {} seconds').format(elapsed)
Dan, the run time is acually less then in my watch timer- why is it?
maybe computer clock speeds...don't know ![]()
Not sure if you're still monitoring this thread but just wanted to comment that the syntax for Python 3.x has changed since Print is now a function so the brackets have to change slightly:
print('Script Complete...run time was... {} seconds'.format(elapsed))Figured I'd share this updated line here in case anyone else is trying to use it. Thanks for providing the original code block!
Implement a Timer class to reuse throughout the code base.
class Timer: def __enter__(self): self.start = time.clock() return self def __exit__(self, *args): self.end = time.clock() self.interval = self.end - self.start
Simple to implement, especially when you wrap up your functions/code blocks into individual def's
def dftest(): #some process wrapped up in this def() #time the process t = Timer() with t: dftest() print "The process took %.2f Milisecs. " % (t.interval)
where i implement your code in my code?
class Timer:
return self
def mainProcess():
counter = 0
print (mxd)
print ('AddLayer')
mapdoc.save()
del mxd
t = Timer()
with t:
mainProcess()
