Execution time- Arcpy
13855
13
03-18-2015 01:08 AM
Yaron_YosefCohen
Hello everyone,
I am working on arcmap 10.3.1  and python 2.7.8.  I need to determine how much time arcpy needed to finish a specific task (add layer) . I'm using this code:
import arcpy,os,sys,string,datetime,timeit
import arcpy.mapping
from arcpy import env
env.workspace = r"C:\Project"
Layer1 = arcpy.mapping.Layer(r"C:\Project\layers\atikot.lyr")
counter = 0
for mxd in arcpy.ListFiles("*.mxd"):
    print (mxd)
    mapdoc = arcpy.mapping.MapDocument(r"C:\Project\\" + mxd)
    df = arcpy.mapping.ListDataFrames(mapdoc, "Layers")[0]
    arcpy.mapping.AddLayer(df ,Layer1, "TOP")
    print ('AddLayer')
    mapdoc.save()
    counter = counter + 1
del mxd
print (counter)
print str(datetime.datetime.now().date())
print time.clock()
When i run it i get:
Project 2.mxd
AddLayer
Project.mxd
AddLayer
soil.mxd
AddLayer
soil_20008.mxd
AddLayer
ta34b_4.mxd
AddLayer
wells.mxd
AddLayer
6
2015-03-18
3.20723655198e-07
I have been unable to get execution times for the processes. when i measured this process with stopper -i got 9.6 second in real time
but in the code the score is 3.207. I dont know if 3.2 is seconds -and if it is that mean this time isn't right.
Any help would be great
DanPatterson_Retired
practice  with your stop watch before you use the time function
copy and paste these in an interactive editor session
>>> import datetime
>>> now = datetime.datetime.now()  # wait a bit, then paste the next line
>>> later = datetime.datetime.now()
>>> # ... your code stuff here or nothing ...
>>> elapsed = later - now
>>> print elapsed
0:00:04.416000
>>> import datetime
>>> print elapsed
0:00:04.416000
And for extra clarity... just substitute the nap_time line with your code block
#  time_timeit_sleep_demo.py
#  [email protected]
import time
import datetime
nap_time = time.sleep(5)  # sleep time in seconds... change to test
print('Nap time was... {} seconds').format(elapsed)
Yaron_YosefCohen
Dan, the run time is acually less then in my watch timer- why is it?
maybe computer clock speeds...don't know
Yaron_YosefCohen
thanks  Dan
FredMitchell
Hi @DanPatterson_Retired,
Not sure if you're still monitoring this thread but just wanted to comment that the syntax for Python 3.x has changed since Print is now a function so the brackets have to change slightly:
print('Script Complete...run time was... {} seconds'.format(elapsed))
Figured I'd share this updated line here in case anyone else is trying to use it. Thanks for providing the original code block!
JamesCrandall
Implement a Timer class to reuse throughout the code base.
class Timer:
    def __enter__(self):
        self.start = time.clock()
        return self
    def __exit__(self, *args):
        self.end = time.clock()
        self.interval = self.end - self.start
Simple to implement, especially when you wrap up your functions/code blocks into individual def's
def dftest():
    #some process wrapped up in this def()
#time the process
t = Timer()
with t:
    dftest()
print "The process took %.2f Milisecs. " % (t.interval)
Yaron_YosefCohen
where i implement your code in my code?
JamesCrandall
class Timer:
        return self
def mainProcess():
    counter = 0
        print (mxd)
        print ('AddLayer')
        mapdoc.save()
    del mxd
t = Timer()
with t:
    mainProcess()
