Errors when publishing more than one CSV to AGOL
624
05-03-2021 01:28 PM
ChrisPeak
I'm trying to publish multiple CSV's as hosted tables in ArcGIS Online, using the Python API version 1.7.1.   Python version is 3.7.10.
My code works for the first layer I add and publish, but any subsequent CSV's produce an error:
File "<stdin>", line 1, in <module>
File "my_directory\Continuum\anaconda3\lib\site-packages\arcgis\gis\__init__.py", line 9029, in publish
elif not buildInitialCache and ret[0]['type'].lower() == 'image service':
KeyError: 'type'
This works:
from arcgis.gis import GIS
gis = GIS(my_organizations_AGOL_portal, my_username, my_pw)
exported = gis.content.add(
   {'title': 'test_csv1', 'tags':'test', 'description':'some desc'},
   data='csv1.csv')
pub_csv = exported.publish(publish_parameters={"type":"csv","locationType":"none"})
When I try to export and publish a second CSV, as in the following, I get the error on the last line:
exported = gis.content.add({'title': 'test_csv2', 'tags':'test', 'description':'some desc'}, data='csv2.csv')
The two CSV files are copies of the same file so I know this isn't an issue with the CSV itself.  And if I reverse the order of the files, the first in my batch always succeeds and the second fails.
If I delete the first CSV then the second one can successfully be published.
Any help is appreciated!
