error script with project_management tool
1562
6
11-25-2013 06:14 AM
francescodi_vito
hello guys,
I'm using the script for project features that is in the help of arcgis desktop, but I get a generic error 999999
this is the script code
[HTML]
import arcpy, os
from arcpy import env
# Enviroment Setting
env.workspace = "C:/Users/fdivito/Documents/Commesse/LOMBARDIA_INFORMATICA/PolidroDati/DATI_ANALISI/Feature.gdb"
env.overwriteOutput = True
# Imposta variabile locale su cui viene salvato il risultato dell'operazione
outWorkspace = "C:/Users/fdivito/Documents/Commesse/LOMBARDIA_INFORMATICA/PolidroDati/DATI_ANALISI/Feature_utm.gdb"
try:
    # Use ListFeatureClasses to generate a list of inputs
    for infc in arcpy.ListFeatureClasses():
        # Determine if the input has a defined coordinate system, can't project it if it does not
        dsc = arcpy.Describe(infc)
        if dsc.spatialReference.Name == "Unknown":
            print ('skipped this fc due to undefined coordinate system: ' + infc)
        else:
            # Determine the new output feature class path and name
            outfc = os.path.join(outWorkspace, infc)
            # Set output coordinate system
            outCS = arcpy.SpatialReference('WGS_1984_UTM_Zone_32N')
            # run project tool
            arcpy.Project_management(infc, outfc, outCS)
            # check messages
            print(arcpy.GetMessages())
except arcpy.ExecuteError:
    print(arcpy.GetMessages(2))
except Exception as ex:
    print(ex.args[0])
[/HTML]
Any  help please?
Bye
Thanks
MichaelVolz
Esteemed Contributor
Can you try adding some print statements into your code to make sure the variables are being properly populated?  Then please include output in a reply.
JakeSkinner
Esri Esteemed Contributor
Hi Francesco,
Remove the underscores in the spatial reference name.  Try the following:
outCS = arcpy.SpatialReference('WGS 1984 UTM Zone 32N')
MichaelVolz
Jake:
In a script I have had for awhile I would have the following projection information to convert to UTM PA South
outCS = arcpy.SpatialReference("PROJCS['WGS_1984_Web_Mercator',GEOGCS['GCS_WGS_1984_Major_Auxiliary_Sphere',DATUM['D_WGS_1984_Major_Auxiliary_Sphere',SPHEROID['WGS_1984_Major_Auxiliary_Sphere',6378137.0,0.0]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]],PROJECTION['Mercator'],PARAMETER['False_Easting',0.0],PARAMETER['False_Northing',0.0],PARAMETER['Central_Meridian',0.0],PARAMETER['Standard_Parallel_1',0.0],UNIT['Meter',1.0]]", "NAD_1983_To_WGS_1984_1;WGS_1984_Major_Auxiliary_Sphere_To_WGS_1984", "PROJCS['NAD_1983_StatePlane_Pennsylvania_South_FIPS_3702_Feet',GEOGCS['GCS_North_American_1983',DATUM['D_North_American_1983',SPHEROID['GRS_1980',6378137.0,298.257222101]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]],PROJECTION['Lambert_Conformal_Conic'],PARAMETER['False_Easting',1968500.0],PARAMETER['False_Northing',0.0],PARAMETER['Central_Meridian',-77.75],PARAMETER['Standard_Parallel_1',39.93333333333333],PARAMETER['Standard_Parallel_2',40.96666666666667],PARAMETER['Latitude_Of_Origin',39.33333333333334],UNIT['Foot_US',0.3048006096012192]]")
Is there simpler nomenclature in the below form that could have been instead to do this reprojection?
If so, what would my SpatialReference nomenclature be for UTM PA South?
JakeSkinner
Hi Michael,
You could perform the following:
outCS = arcpy.SpatialReference("NAD 1983 StatePlane Pennsylvania South FIPS 3702 (US Feet)")
arcpy.env.geographicTransformations = "NAD_1983_To_WGS_1984_1"
arcpy.Project_management(fc, fc + "_project", outCS)
MichaelVolz
Jake:
My reprojection additionally needed a transformation, unlike the original poster, which is accounted for with my original much longer nomenclature?
JakeSkinner
Yes, the transformation is handled by the env variable arcpy.env.geographicTransformations.  This is a semicolon delimited string, so you can specify multiple transformations if needed.  Ex:
arcpy.env.geographicTransformations = "Arc_1950_To_WGS_1984_5; PSAD_1956_To_WGS_1984_6"
