ERROR 999999 when running python as service
1586
5
11-22-2013 12:39 AM
irishadar
hi all,
the code below runs ok from ArcCatalog,
but once i publish it it fail with error  :
File "D:\arcgisserver\directories\arcgissystem\arcgisinput\UploadeS.GPServer\extracted\v101\my_toolboxes\UPLOADER.py", line 55,
in  arcpy.CalculateField_management(lyrSource, g_ESRI_variable_3, SURVEY_ID, "PYTHON", "")
File "c:\program files\arcgis\server\arcpy\arcpy\management.py", line 3129,
 in CalculateField raise e ExecuteError: ERROR 999999: Error executing function.
 General function failure Failed to execute (CalculateField).
 Failed to execute (UploadeShapeFiles). Failed to execute (UploadeShapeFiles)."
it is allso works if i use only "appand"
any one notice what is worng?!!!
# Import arcpy module
import arcpy
arcpy.env.overwriteOutput=True
arcpy.env.workspace="d:\\GIS_PROC\\TEMP.gdb"
# Load required toolboxes
#arcpy.ImportToolbox("Model Functions")
#getting user parms
#LyrNamesStr=arcpy.GetParameterAsText(0)
#SURVEY_ID=arcpy.GetParameterAsText(1)
# hard coded parms for testing
LyrNamesStr="area_528d0df4ec13b"
SURVEY_ID=99
LyrNames =LyrNamesStr.split(',')
print LyrNames
startUrl ='D:\\AllData\\';
EndUrl='.shp'
destenationUrlStart="C:\\Users\\administrator.IAA\\AppData\\Roaming\\ESRI\\Desktop10.1\\ArcCatalog\\[email protected]\\"
#UPL_LINE UPL_POLY UPL_POINT
# Local variables:
for lyr in LyrNames:
    lyrSource=startUrl+lyr+EndUrl
    print '1'
    desc=arcpy.Describe(lyrSource)
    #print "Feature Type:  " + desc.shapeType
    if desc.shapeType == "Polygon":
        destLyr=destenationUrlStart+"\\MSURVEY.UPL_POLY"
        print 'polygon'
        FieldAllocation="SNUMBER \"SNUMBER\" true true false 2 Short 0 4 ,First,#,"+lyrSource+",Snumber,-1,-1;ELEMENTS \"ELEMENTS\" true true false 50 Text 0 0 ,First,#,"+lyrSource+",elements,-1,-1;REMARKS \"REMARKS\" true true false 100 Text 0 0 ,First,#,"+lyrSource+",remarks,-1,-1;SSIZE \"SSIZE\" true true false 50 Text 0 0 ,First,#,"+lyrSource+",Ssize,-1,-1;RECOMENDAT \"RECOMENDAT\" true true false 50 Text 0 0 ,First,#,"+lyrSource+",recomendat,-1,-1;GVUL_ATAR \"GVUL_ATAR\" true true false 50 Text 0 0 ,First,#,"+lyrSource+",gvul_atar,-1,-1;PERIOD \"PERIOD\" true true false 50 Text 0 0 ,First,#,"+lyrSource+",period,-1,-1;GPS_DATE \"GPS_DATE\" true true false 36 Date 0 0 ,First,#,"+lyrSource+",Gps_Date,-1,-1;DATAFILE \"DATAFILE\" true true false 50 Text 0 0 ,First,#,"+lyrSource+",Datafile,-1,-1;METHOD_TYP \"METHOD_TYP\" true true false 4 Long 0 8 ,First,#,"+lyrSource+",METHOD_TYP,-1,-1;CRE_METHOD \"CRE_METHOD\" true true false 4 Long 0 8 ,First,#,"+lyrSource+",CRE_METHOD,-1,-1;SURV_ID \"SURV_ID\" true true false 4 Long 0 7 ,First,#,"+lyrSource+",SURV_ID,-1,-1;SHAPE.AREA \"SHAPE.AREA\" false false true 0 Double 0 0 ,First,#;SHAPE.LEN \"SHAPE.LEN\" false false true 0 Double 0 0 ,First,#"
        #arcpy.RepairGeometry_management(lyrSource, "DELETE_NULL")
        arcpy.CalculateField_management(lyrSource, "SURV_ID", SURVEY_ID, "PYTHON", "")
        arcpy.Append_management(RepairedArea, destLyr,"NO_TEST",FieldAllocation, "")
    elif desc.shapeType=="Point":
        destLyr=destenationUrlStart+"MSURVEY.UPL_POINT"
        print 'Point'
        FieldAllocation="SNUMBER \"SNUMBER\" true true false 2 Short 0 4 ,First,#,"+lyrSource+",Snumber,-1,-1;ELEMENTS \"ELEMENTS\" true true false 50 Text 0 0 ,First,#,"+lyrSource+",elements,-1,-1;REMARKS \"REMARKS\" true true false 100 Text 0 0 ,First,#,"+lyrSource+",remarks,-1,-1;SSIZE \"SSIZE\" true true false 50 Text 0 0 ,First,#,"+lyrSource+",Ssize,-1,-1;RECOMENDAT \"RECOMENDAT\" true true false 50 Text 0 0 ,First,#,"+lyrSource+",recomendat,-1,-1;GVUL_ATAR \"GVUL_ATAR\" true true false 50 Text 0 0 ,First,#,"+lyrSource+",gvul_atar,-1,-1;PERIOD \"PERIOD\" true true false 50 Text 0 0 ,First,#,"+lyrSource+",period,-1,-1;GPS_DATE \"GPS_DATE\" true true false 36 Date 0 0 ,First,#,"+lyrSource+",Gps_Date,-1,-1;DATAFILE \"DATAFILE\" true true false 50 Text 0 0 ,First,#,"+lyrSource+",Datafile,-1,-1;METHOD_TYP \"METHOD_TYP\" true true false 4 Long 0 8 ,First,#,"+lyrSource+",METHOD_TYP,-1,-1;CRE_METHOD \"CRE_METHOD\" true true false 4 Long 0 8 ,First,#,"+lyrSource+",CRE_METHOD,-1,-1;SURV_ID \"SURV_ID\" true true false 4 Long 0 7 ,First,#,"+lyrSource+",SURV_ID,-1,-1"
        arcpy.Append_management(lyrSource, destLyr, "NO_TEST",FieldAllocation, "")
    elif desc.shapeType=="Polyline":
        print 'Polyline'
        destLyr=destenationUrlStart+"MSURVEY.UPL_LINE"
        FieldAllocation="SNUMBER \"SNUMBER\" true true false 2 Short 0 4 ,First,#,"+lyrSource+",Snumber,-1,-1;ELEMENTS \"ELEMENTS\" true true false 50 Text 0 0 ,First,#,"+lyrSource+",elements,-1,-1;REMARKS \"REMARKS\" true true false 100 Text 0 0 ,First,#,"+lyrSource+",remarks,-1,-1;SSIZE \"SSIZE\" true true false 50 Text 0 0 ,First,#,"+lyrSource+",Ssize,-1,-1;RECOMENDAT \"RECOMENDAT\" true true false 50 Text 0 0 ,First,#,"+lyrSource+",recomendat,-1,-1;GVUL_ATAR \"GVUL_ATAR\" true true false 50 Text 0 0 ,First,#,"+lyrSource+",gvul_atar,-1,-1;PERIOD \"PERIOD\" true true false 50 Text 0 0 ,First,#,"+lyrSource+",period,-1,-1;GPS_DATE \"GPS_DATE\" true true false 36 Date 0 0 ,First,#,"+lyrSource+",Gps_Date,-1,-1;DATAFILE \"DATAFILE\" true true false 50 Text 0 0 ,First,#,"+lyrSource+",Datafile,-1,-1;METHOD_TYP \"METHOD_TYP\" true true false 4 Long 0 8 ,First,#,"+lyrSource+",METHOD_TYP,-1,-1;CRE_METHOD \"CRE_METHOD\" true true false 4 Long 0 8 ,First,#,"+lyrSource+",CRE_METHOD,-1,-1;SURV_ID \"SURV_ID\" true true false 4 Long 0 7 ,First,#,"+lyrSource+",SURV_ID,-1,-1;SHAPE.LEN \"SHAPE.LEN\" false false true 0 Double 0 0 ,First,#"
print 'finish'
irishadar
hi again ,I've managed to focus on the problem , this is the new script it fails with general error 999999:
import arcpy
# Script arguments
Expression = arcpy.GetParameterAsText(0)
# Local variables:
area_shp = r"D:\support\iris\area.shp"
# Process: Calculate Field
arcpy.CalculateField_management(area_shp, "SURV_ID", Expression, "PYTHON", "")
has this happened to anyone ?
iris
MathewCoyle
Honored Contributor
What is your expression? And why not use an update cursor?
irishadar
hi , my expression is long.
and i have already tried to replace with cursor update but it fails in with the same error .
startUrl ="D:\\AllData\\area.shp"
#arcpy.CalculateField_management(RepairedArea, "SURV_ID", "666", "PYTHON")
rows = arcpy.UpdateCursor(startUrl)
# Update the field used in buffer so the distance is based on the
# road type. Road type is either 1, 2, 3 or 4. Distance is in meters.
for row in rows:
    row.setValue("SURV_ID", 7878)
    rows.updateRow(row)
# Delete cursor and row objects to remove locks on the data
del row
del rows
print 'finish'
MathewCoyle
Honored Contributor
Check to make sure the field has that exact name and it is the right type.
irishadar
yes i have  it is a match ,
the scrip tool is working well under arcmap or arccatalog it is only fails when i publish it as a services .
this is the exact error
Error executing tool.: Traceback (most recent call last):
File "D:\arcgisserver\directories\arcgissystem\arcgisinput\fieldcalc1.GPServer\extracted\v101\my_toolboxes\calc1.py", line 22,in  arcpy.CalculateField_management(area_shp, g_ESRI_variable_2, g_ESRI_variable_3, "PYTHON", "")
File "c:\program files\arcgis\server\arcpy\arcpy\management.py", line 3129, in CalculateField raise e ExecuteError: ERROR 999999: Error executing function. General function failure Failed to execute (CalculateField). Failed to execute (fieldcalc1). Failed to execute (fieldcalc1).
