Error running field calculator
2339
07-12-2011 10:31 AM
deleted-user-rQoEFM5qzbHE
I am attempting to copy over values from a string field to an integer field. In the case of an empty string, I want to make the value null but am getting the following error:
ERROR 000539: Error running expression: getDOT( " ") <type 'exceptions.NameError'>: global name 'null' is not defined
Failed to execute (Calculate Field (7))
The code block that I am using the field calculator is:
def getDOT(dot):
  if (len(dot) > 1):
    result = int(dot)
  else:
    result = null
  return result
Is it possible to set integer field to a null value? I have done it in the past, but cannot seem to get it to work now.
jeremy
TerrySilveus
still learning python myself, but you might try None instead of null
Here is another issue I am having. This string field has values that are not numbers. For example, one of the records has a value of 'UNKNOWN'. Since I am copying these values over to an integer field, this record should have a value of 0. However, I cannot figure out how to catch for this type of situation. Here is the code I am trying to use:
def getDOT(dot):
  if (isinstance(int(dot), int)):
    result = int(dot)
  else:
    result = None
  return result
It doesn't like the second line.When it tries to convert the above example to an int, it crashes. This makes sense, but I cannot seem to figure out another way to approach this problem. Anybody have any ideas?
jeremy
ChristopherFricke1
You should use a try/except statement http://docs.python.org/tutorial/errors.html
def getDOT(dot):
def getDOT(dot):
    try:
        result = int(dot)
    except:
        result = Null
    finally:
        return result
TerrySilveus
and I'm not sure of your purposes, but you may not want to make an "UNKNOWN" 0 because 0 may be a legitimate value, it would probably be better to make that value NULL which christophfricke's code should do for you.
