Error returning Shape extent
2075
03-03-2021 09:09 AM
CliveSwan
Greetings,
I am using the ESRI example to try and return the Features extent, getting an error:
Extent—ArcGIS Pro | Documentation
TypeError: '<' not supported between instances of 'Polyline' and 'Polyline'
 The error is at the for row in sorted:
for dirpath, dirnames, filenames in arcpy.da.Walk(workspace, topdown=True, datatype=data_type):
    #datasets = [''] + datasets if datasets is not None else []
    for filename in filenames:
            for row in sorted(arcpy.da.SearchCursor(filename, ['Shape@'])):
                #print(filename)
                extent = row[0].extent
                print(filename, extent)
Appreciate any pointers.
Clive
2 Solutions
CliveSwan
It didn't like the sorted..
jcarlson
It probably would, but you'd need to give it a non-spatial field on which to sort.
- Josh Carlson
Kendall County GIS
CliveSwan
jcarlson
- Josh Carlson
Kendall County GIS
