Error On ArcPy Merge
3756
08-19-2015 11:44 PM
BruceGreen
Using ArcGIS 10.2 Desktop I am trying to run a Merge function by Arcpy as
    # Set environment settings
    env.workspace = "E:\\GIS\\ROR"
    path = "E:\\GIS\\Data\\"
    featureClass = "band-tailed_pigeon.shp"
    InputFeature = path + featureClass
    FinaloutLocation = "E:\\GIS\\Data\\Final"
    dissolve_1 = "dissolved_1.shp"
    dissolve_2 = "dissolved_2.shp"
    dissolve_3 = "dissolved_3.shp"
    dissolve_4 = "dissolved_4.shp"
    dissolve_5 = "dissolved_5.shp"
    # Process: Merge
    inFeaturesToMerge = [dissolve_1,dissolve_2,dissolve_3,dissolve_4,dissolve_5]
    arcpy.Merge_management(inFeaturesToMerge, FinaloutLocation)
but I am getting this error:
    ExecuteError: Failed to execute. Parameters are not valid.
    ERROR 000725: Output Dataset: Dataset E:\GIS\Data\Final already exists.
Can you please let me know why this is happening?
NeilAyres
MVP Alum
Well, FinaloutLocation = "E:\\GIS\\Data\\Final", is just that, a file location, not the name of a feature class in a gdb or a shapefile name.
Why are you defining input feature names then do nothing with them.
And please search for a read how to post code here.
NeilAyres
MVP Alum
RebeccaStrauch__GISP
Link for Posting Code blocks in the new GeoNet​  as mentioned by Neil.
