error : no module named arcpy
7855
12
01-06-2016 04:31 PM
ben_abdallahmhd
Hi, i have a problem with arcpy when i try to import it in a script with idle the message
no "module named arcpy" appear. But when i run it directly in arcgis.
The second problem is the no recognition of the feqtureclqss . the message that appearr is : the featureclass doesntexist.
Remarque I use ArcSDE connection and ArcGIS 10.1
Thank you
DanPatterson_Retired
Thanks for the update... I will add Rebecca's solution to the list of possible solutions
RebeccaStrauch__GISP
Are you using IDLE to edit withint ArcGIS.  See
40263 - Change the default editor for a Python Toolbox from Notepad to IDLE
for how to set up IDLE as your default editor.  If using a standalone version of IDLE, there is probably a system setting you need to setup for the python path.  Here are some tips for finding the correct path
Locating Python and adding it to your system Path | Python, GIS and stuff…
This link may also help in resolving your issue, although it mention 10.0 not 10.1
arcgis 10.0 - issues importing arcpy in Python IDLE - Geographic Information Systems Stack Exchange
Tip from that thread...
Tip:
If importing ArcPy produces either of the following errors, the required modules could not be found: ImportError: No module named arcpy ImportError: No module named arcgisscripting
To address this, browse using Windows Explorer to the python26\Lib\site-packages folder and add or edit the Desktop10.pth file. The file should contain the two lines shown below (corrected to your system's path if they do not match):
  • C:\Program Files\ArcGIS\Desktop10.0\arcpy
  • C:\Program Files\ArcGIS\Desktop10.0\bin
ben_abdallahmhd
Hi Rebecca, thank tou
I will do this or reinstall ArcGis!
