error message at raster calculator
1508
6
05-11-2012 07:22 AM
GerryGabrisch
My Python code throws an error at the first raster calculator statement claiming that no cell size or extent are set.  I don't see  why this is necessary in this script but I put in some extent and cell size statements anyway.  That didn't help, the code still throws the same error at the first raster calculator statement.  Any help is welcomed.
try:
    import arcpy, os, sys, traceback
    from arcpy.sa import *
    arcpy.CheckOutExtension("Spatial")
    degreesSlope = Raster(r"C:\gtemp\FS_test\slope_degree")
    totalSoilThickness = Raster(r"C:\gtemp\FS_test\soildepth")
    saturatedSoilThickness = Raster(r"C:\gtemp\FS_test\dw")
    treeRootStrength = Raster(r"C:\gtemp\FS_test\rootcohesion")
    treeSurcharge = Raster(r"C:\gtemp\FS_test\surcharge")
    moistSoilUnitWeight = Raster(r"C:\gtemp\FS_test\moist_uw")
    numerator = "numerator"
    denominator = "denominator"
    #Constants...
    soilCohesion = 10.0
    effectiveInternalAngleofFriction = 10.0
    drySoilUnitWeight = 10.0
    saturatedSoilUnitWeight = 10.0
    waterUnitWeight = 10.0
    rastercalc = r"C:\gtemp\FS_test\dwrastercalc"
    arcpy.env.cellSize = "MAXOF"
    arcpy.env.extent = "MAXOF"
    arcpy.gp.RasterCalculator_sa((treeRootStrength + soilCohesion + Square(Cos(degreesSlope))*(treeSurcharge + moistSoilUnitWeight*(totalSoilThickness - saturatedSoilThickness)+ (saturatedSoilUnitWeight-waterUnitWeight)*saturatedSoilThickness)*Tan(effectiveInternalAngleofFriction)), numerator)
    arcpy.gp.RasterCalculator_sa((Sin(degreesSlope)*Cos(degreesSlope))*(treeSurcharge + moistSoilUnitWeight*(totalSoilThickness - saturatedSoilThickness) + drySoilUnitWeight * saturatedSoilThickness), denominator)
    arcpy.gp.RasterCalculator_sa(numerator/denominator, rastercalc )
    arcpy.AddMessage("Done!")
except arcpy.ExecuteError:
    msgs = arcpy.GetMessages(2)
    arcpy.AddError(msgs)
    print msgs
except:
    tb = sys.exc_info()[2]
    tbinfo = traceback.format_tb(tb)[0]
    pymsg = "PYTHON ERRORS:\nTraceback info:\n" + tbinfo + "\nError Info:\n" + str(sys.exc_info()[1])
    msgs = "ArcPy ERRORS:\n" + arcpy.GetMessages(2) + "\n"
    arcpy.AddError(pymsg)
    print pymsg + "\n"
    print msgs
JakeSkinner
Esri Esteemed Contributor
Hi Gerry,
The Raster Calculator needs to be executed in Desktop or Model Builder.  See here:
The Raster Calculator tool is intended  for use in the ArcGIS Desktop  application only as a GP tool dialog box  or in ModelBuilder. It is not   intended for use in scripting and is not  available in the ArcPy  Spatial Analyst module.
You will want to use the Spatial Analyst 'Math' tools to perform your Raster calculations (i.e. Times, Plus, etc).
GerryGabrisch
OK, I removed the raster calculator functions from the script.  According to the literature I can use raster calculator like expression (+,-,/...) as long as I cast the raster as 'rasters'.  I can get something like the below to work without error, but I cant get passed 'numerator' in the code below without getting the cell size and extent not set error.
Raster("test1")
Raster(test2")
thesum = test1 + test2
try:
    from arcpy import env
    arcpy.AddMessage("\n\nCalculate Slope Factor of Safety")
    #Grids
    result = "result"
    #Constants...
    soilCohesion = 10.0
    numerator =((treeRootStrength + soilCohesion + Square(Cos(degreesSlope))*(treeSurcharge + moistSoilUnitWeight*(totalSoilThickness - saturatedSoilThickness)+ (saturatedSoilUnitWeight-waterUnitWeight)*saturatedSoilThickness)*Tan(effectiveInternalAngleofFriction)))
    denominator =((Sin(degreesSlope)*Cos(degreesSlope))*(treeSurcharge + moistSoilUnitWeight*(totalSoilThickness - saturatedSoilThickness) + drySoilUnitWeight * saturatedSoilThickness), denominator)
    result =(numerator/denominator)
    result.save(rastercalc)
    # Process: Raster Calculator
    #arcpy.gp.RasterCalculator_sa("treeRootStrength + soilCohesion + Square(Cos(degreesSlope))*(treeSurcharge + moistSoilUnitWeight*(totalSoilThickness - saturatedSoilThickness)+ (saturatedSoilUnitWeigh-waterUnitWeight)*saturatedSoilThickness)*Tan(effectiveInternalAngleofFriction))/((Sin(degreesSlope)*Cos(degreesSlope))*(treeSurcharge + moistSoilUnitWeight*(totalSoilThickness - saturatedSoilThickness) + drySoilUnitWeight * saturatedSoilThickness))", rastercalc)
    print msgs
except:
    print pymsg + "\n"
    print msgs
curtvprice
Both you and the parser will have a better chance of getting it right (or at least isolate the issues)  if you break this up into smaller chunks.
x1 =treeRootStrength + soilCohesion
x2 = Square(Cos(degreesSlope)) * treeSurcharge + moistSoilUnitWeight * (totalSoilThickness - saturatedSoilThickness)
I've found this help article very, uh, helpful:
Building" rel="nofollow" target="_blank">http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.htm... Complex Statements
JakeSkinner
It looks like there may be a bug with "MAXOF" & "MINOF" properties.  I tested this and always received a Runtime Error:
RuntimeError: No CellSize and Extent set
If you set the 'arcpy.env.cellSize' and 'arcpy.env.extent' to a raster, or to a constant (i.e. 10) the code should work.  You may want to report this issue to Tech Support.
GerryGabrisch
Thanks, Jake.  Setting the env properties to a grid worked.
GerryGabrisch
Now that I got my tool running as a standalone script I set it to work as an ArcToolbox tool.  It throws an error  at line 62 (numerator) where the standalone does not...looks line another bug.
Error Info:
ERROR 000824: The tool is not licensed.
ArcPy ERRORS:
try:
    arcpy.SetProduct("ArcInfo")
    arcpy.AddMessage("beta by Gerry Gabrisch, 5-4-2012")
    #Get input parameters using ArcToolbox tool
    degreesSlope = arcpy.GetParameterAsText(0)
    totalSoilThickness = arcpy.GetParameterAsText(1)
    saturatedSoilThickness = arcpy.GetParameterAsText(2)
    treeRootStrength = arcpy.GetParameterAsText(3)
    treeSurcharge = arcpy.GetParameterAsText(4)
    soilCohesion = float(arcpy.GetParameterAsText(5))
    effectiveInternalAngleofFriction = float(arcpy.GetParameterAsText(6))
    drySoilUnitWeight = float(arcpy.GetParameterAsText(7))
    moistSoilUnitWeight = arcpy.GetParameterAsText(8)
    saturatedSoilUnitWeight = float(arcpy.GetParameterAsText(9))
    waterUnitWeight = float(arcpy.GetParameterAsText(10))
    rastercalc = arcpy.GetParameterAsText(11)
    ##Use For hardcoding
    ##Grids
    #degreesSlope = r"C:\gtemp\FS_test\slope_degree"
    #totalSoilThickness = r"C:\gtemp\FS_test\soildepth"
    #saturatedSoilThickness = r"C:\gtemp\FS_test\dw"
    #treeRootStrength = r"C:\gtemp\FS_test\rootcohesion"
    #treeSurcharge = r"C:\gtemp\FS_test\surcharge"
    #moistSoilUnitWeight = r"C:\gtemp\FS_test\moist_uw"
    ##Constants...
    #soilCohesion = 10.0
    #effectiveInternalAngleofFriction = 10.0
    #drySoilUnitWeight = 10.0
    #saturatedSoilUnitWeight = 10.0
    #waterUnitWeight = 10.0
    #Set the output cell size,  mask, and cell registration...
    arcpy.env.cellSize = degreesSlope
    arcpy.env.extent = degreesSlope
    arcpy.env.snapeRaster = degreesSlope
    #Cast input rasters to in-memory raster layers...
    degreesSlope = Raster(degreesSlope)
    totalSoilThickness = Raster(totalSoilThickness)
    saturatedSoilThickness = Raster(saturatedSoilThickness)
    treeRootStrength = Raster(treeRootStrength)
    treeSurcharge = Raster(treeSurcharge)
    moistSoilUnitWeight = Raster(moistSoilUnitWeight)
    result = "result"
    numerator =(treeRootStrength + soilCohesion + Square(Cos(degreesSlope))*(treeSurcharge + moistSoilUnitWeight*(totalSoilThickness - saturatedSoilThickness)+ (saturatedSoilUnitWeight-waterUnitWeight)*saturatedSoilThickness)*Tan(effectiveInternalAngleofFriction))
    denominator =((Sin(degreesSlope)*Cos(degreesSlope))*(treeSurcharge + moistSoilUnitWeight*(totalSoilThickness - saturatedSoilThickness) + drySoilUnitWeight * saturatedSoilThickness))
    #Do the last division....
    result = numerator/denominator
    #Save the in-memory results to disk...
#Catch ESRI errors here...
    print msgs
#Catch Python errors here...
except:
    print pymsg + "\n"
    print msgs
