error: global name 'Primary_OH' is not defined
13643
43
12-27-2019 11:14 AM
RickHawkins
I am trying to run my program and when i get to this part of the program
I get the error that global name 'Primary_OH is not defined. Can someone look at my code and tell what i need to do to fix this.
Tags (1)
RickHawkins
from tkinter import *
from tkinter import messagebox
import Tkinter, arcpy
#mxd = arcpy.mapping.MapDocument("C:/GISMAPS/LUS Map.mxd")
mxd = arcpy.mapping.MapDocument(r"C:/GISMAPS/LUS Map.mxd")
#mxd = arcpy.mapping.MapDocument("CURRENT")
#reset (overwrite) MakeFeatureLayer_management. This is needed so you can run the program more than once.
#delete the layer
#arcpy.Delete_managment
#set variables for when you run the section of program that set the layers that should be on
geodatabase = "C:\gismaps\LusData.mdb"
dataset = "ElectricData"
feature_class = "PriOHElectricLineSegment"
#Create main window
window = Tk()
window.title("Feeders Selection")
window.geometry("680x500")
window.iconbitmap('C:/GISMAPS/lus.ico')
#Define the frame for the feeders to be displayed
frame = Frame(window)
frame.grid(row=1, column=1, padx=15, pady=5)
listNodes = Listbox(frame, width=10, height=10, font=("Helvetica", 10))
listNodes.pack(side="left", fill="y")
#Define the scrollbar in frame window
scrollbar = Scrollbar(frame, orient="vertical")
scrollbar.config(command=listNodes.yview)
scrollbar.pack(side="right", fill="y")
listNodes.config(yscrollcommand=scrollbar.set)
#Add the selection of all feeders
for item in [2050, 2051, 2052,
             3050, 3051, 3052, 3550,
             4050, 4051, 4052,
             5050, 5051, 5052]:
    listNodes.insert(END, item)
    feeder = listNodes.get(ACTIVE)
#Define all of the checkboxes
prioh_var = IntVar()
priug_var = IntVar()
secoh_var = IntVar()
secug_var = IntVar()
fuse_var = IntVar()
switch_var = IntVar()
sp_var = IntVar()
cap_var = IntVar()
rec_var = IntVar()
pinhook_var = IntVar()
mall_var = IntVar()
peck_var = IntVar()
pri_oh = Checkbutton(window, text = "Primary Overhead", variable = prioh_var,onvalue = 1, offvalue = 0, height=2, width = 20).place(x=2, y=175)
pri_ug = Checkbutton(window, text = "Primary Underground", variable = priug_var,onvalue = 1, offvalue = 0, height=2, width = 20).place(x=12, y=200)
sec_oh = Checkbutton(window, text = "Secondary Overhead", variable = secoh_var,onvalue = 1, offvalue = 0, height=2, width = 20).place(x=8, y=225)
sec_ug = Checkbutton(window, text = "Secondary Underground", variable = secug_var,onvalue = 1, offvalue = 0, height=2, width = 20).place(x=18, y=250)
fuse = Checkbutton(window, text = "Fuse", variable = fuse_var,onvalue = 1, offvalue = 0, height=2, width = 20).place(x=400, y=10)
switch = Checkbutton(window, text = "Switch", variable = switch_var,onvalue = 1, offvalue = 0, height=2, width = 20).place(x=405, y=35)
servicepoint = Checkbutton(window, text = "Service Point", variable = sp_var,onvalue = 1, offvalue = 0, height=2, width = 20).place(x=420, y=88)
capacitor = Checkbutton(window, text = "Capacitor", variable = cap_var,onvalue = 1, offvalue = 0, height=2, width = 20).place(x=412, y=60)
recloser = Checkbutton(window, text = "Recloser", variable = rec_var,onvalue = 1, offvalue = 0, height=2, width = 20).place(x=409, y=87)
pinhook = Checkbutton(window, text = "Pinhook", variable = pinhook_var, state = DISABLED, onvalue = 1, offvalue = 0, height=2, width = 20).place(x=175, y=15)
mall = Checkbutton(window, text = "Mall", variable = mall_var, state = DISABLED, onvalue = 1, offvalue = 0, height=2, width = 20).place(x=165, y=45)
peck = Checkbutton(window, text = "Peck", variable = peck_var, state = DISABLED, onvalue = 1, offvalue = 0, height=2, width = 20).place(x=165, y=75)
#Commit all of the options
def commit():
#check to see which inputs have been selected
#Primary Overhead
    if prioh_var.get() == 1:
        print("pri_oh = 1")
	# show primary overhead feeder where feederid = feeder -ie: [FEEDERID] = "2050"
        print "Primary_OH"
        layer_name = "Primary OH"
        primary_oh = arcpy.mapping.ListLayers(mxd, layer_name)[0]
        primary_oh.definitionQuery = "[FEEDERID] = '2050'"
        print feeder
        #Primary_OH_path = r"{0}\{1}\{2}".format(geodatabase, dataset, feature_class)
        #Primary_OH = arcpy.MakeFeatureLayer_management(Primary_OH_path, "Primary_OH_layer2")
    else:
        print("pri_oh = 0")
		# do not display primary overhead feeder for [FEEDERID] = "2050"
#Primary Underground
	if priug_var.get() == 1:
		print("pri_ug = 1")
		layer_name = "Primary UG"
        primary_ug = arcpy.mapping.ListLayers(mxd, layer_name)[0]
        primary_ug.definitionQuery = "[FEEDERID] = '2050'"
        print feeder
    #else:
        #print("pri_ug = 0")
        # do not display primary underground feeder for [FEEDERID] = "2050"
    mxd.save()
    return
#reset all variables
#def reset():
#Button to run the commit command
Button(window, text="commit", command=commit).place(x=300, y=350)
#Button to run the reset command
#Button(window, text="reset", command=reset).place(x=400, y=350)
#Quit the program
Button(window, text="Quit", command=window.destroy).place(x=500, y=350)
window.mainloop()
Still getting the same error.
RickHawkins
Is there a way to not save the mxd file but refresh screen to see the changes.
RickHawkins
Javier,
for this query in arcGIS
Do these lines in the python script do the same thing?
When i apply the query from ArcGIS all of the primaryOH that is not part of 2050 turns off.
RickHawkins
Javier,
It looks like the code you sent me is working. I had to quit the script for the changes to show up.
Thank you for all of your help
