ERROR 999999 With arcpy.geocoding.CreateFeatureLocator()
1077
08-22-2024 08:57 AM
MichaelAscher
I am trying to automate the process of updating feature locators for our ArcGIS Pro desktop apps. The goal is to take the layer from ArcGIS Online and make the locators, then put them in a folder on a local network drive. I have this code, but `GasCurbValveLocator` always errors with error 999999, failed to execute and no other description.
import os
import zipfile
from arcgis.gis import GIS
import arcpy
if __name__ == '__main__':
    print('Start')
    locators = [
            "name": "AddressLocator",
            "link": 'https://services5.arcgis.com/g3r4E4Xlpygk5wEz/arcgis/rest/services/Addresses/FeatureServer/0',
            "map": """
                "'*Name' FullStName VISIBLE NONE"
            "etc": """
                "'UnitNumber' UnitNum;
                'StreetAddress' Address;
                'CityName' City;
                'PostalCode' Zip;
                'LocationName' PlaceName;
                'PINNumber' PIN;
                'Subdiv' Subdivision;
                'AddressNumber' AddrNum"
            "name": "BuildingNameLocator",
            "link": 'https://services5.arcgis.com/g3r4E4Xlpygk5wEz/arcgis/rest/services/Buildings_Footprints/FeatureServer/8',
            "map": "'*Name' BldgName VISIBLE NONE"
            "name": "GasCurbValveLocator",
            "link": 'https://services5.arcgis.com/g3r4E4Xlpygk5wEz/arcgis/rest/services/Gas_Curb_Valve_GPS/FeatureServer/0',
            "map": "'*Name' ValveID VISIBLE NONE"
            "name": "GasMainValveLocator",
            "link": 'https://services5.arcgis.com/g3r4E4Xlpygk5wEz/arcgis/rest/services/GasValveLive/FeatureServer/0',
            "name": "HydrantLocator",
            "link": 'https://services5.arcgis.com/g3r4E4Xlpygk5wEz/arcgis/rest/services/Hydrants/FeatureServer/3',
            "map": "*Name FACILITYID VISIBLE NONE"
            "name": "RoadIntersectionLocator",
            "link": 'https://services5.arcgis.com/g3r4E4Xlpygk5wEz/arcgis/rest/services/Roads/FeatureServer/31',
            "map": "*Name Alphatag VISIBLE NONE"
            "name": "WaterLateralValveLocator",
            "link": 'https://services5.arcgis.com/g3r4E4Xlpygk5wEz/arcgis/rest/services/Water_All_Valves/FeatureServer/2',
            "name": "WaterMainValveLocator",
            "name": "WaterTowerLocator",
            "link": 'https://services5.arcgis.com/g3r4E4Xlpygk5wEz/arcgis/rest/services/Water_Tower/FeatureServer/0',
            "map": "*Name FacilityID VISIBLE NONE"
    gis = GIS(profile='python_arcgis_credentials')
    arcpy.SignInToPortal("https://www.cfu.maps.arcgis.com")
    for locator in [locators[2]]:
        try:
            print(locator['name'])
            in_features=locator['link'],
            output_locator=os.path.join(r"G:\Water_and_Gas_Operations\ArcGIS\Feature Locator Files", locator['name']),
            search_fields=locator['map'],            # Unique identifier field
            locator_fields=locator.get('etc')
        except Exception as e:
            print(e)
    print('End')
TonyAlmeida
MVP Regular Contributor
If the portal uses built-in security, provide a username and password.
gis = GIS(" portal_url", "username", "password")
Also, maybe use,
from arcgis.features import FeatureLayer
    try:
        print(f"Creating locator for: {locator['name']}")
        layer = FeatureLayer(locator['link'])
        output_fc = "temp_layer"
        arcpy.conversion.FeatureClassToFeatureClass(layer, "in_memory", output_fc)
            in_features=output_fc,
        print(f"Error creating locator for {locator['name']}: {e}")
