ERROR 000358: Invalid expression on MakeFeatureLayer in Script Tool but no error in its Python code
1879
04-16-2024 06:09 AM
JustinKraemer
I have a Script Tool set up and its Python code executes properly when I run it outside of ArcGIS Pro.
But when I execute the script tool that the same code is connected to in ArcGIS Pro, it fails in this way:
First condo ARN value is 410822000220226
Exception encountered
Failed to execute (MakeFeatureLayer).
 The code leading up to this point is:
def condo_script_tool(cntNewCondos, txtARN, subType, ws):
    arcpy.AddMessage("First condo ARN value is " + txtARN)
    env.workspace = ws
    proc_FC = arcpy.CreateFeatureclass_management("in_memory", "condo_proc", "POLYGON", "bc_dev.GIS_ADMIN.parcels")
    target_FC = "parcels"
    # Put in error trapping in case an error occurs when running tool
    try:
        # Make a layer from the feature class with only the parcel that has the desired ARN
        arcpy.MakeFeatureLayer_management(target_FC, "condos_lyr"," \"ROLLNUM15\" = \'" + txtARN + "\' AND SUBTYPE = "+ str(subType))
Now I ask help please on why this code succeeds outside of Pro but fails inside of it. Could the target_FC maybe be the cause of the problem? How can I make it not be?
Justin
BlakeTerhune
I think maybe you are missing single quotes around the last part of the SQL expression for subType. Is it a string or a number value? Try using f-string to build the expression.
f"ROLLNUM15 = '{txtARN}' and SUBTYPE = '{subType}'"
JustinKraemer
Thank you @BlakeTerhune for the suggestion, however it did not change anything.
The Subtype field is a number value. Whether I include the single quotes or not makes no difference.
I expect it's more correct to leave them out given it's not a string data type and "where" clauses later in the script using that field succeed with no single quotes around it.
What other details might I provide, please, to help find a solution?
Bharat
Strangely enough, on 3.2 the code runs fine on notebook but fails on nighly script with the same invalid expression error. I mean the expression is correct so seems like a bug. Did you contact ESRI about it?
