EOL calculating field, single quoted - scrubbing addresses
2380
05-10-2011 08:35 AM
TurnerNowak
Would anyone be able to point me in the right direction ?  I need to figure out how to either make the script ignore these errors and continue to run, or actually be able to handle these lines that currently shut down the script.
C:\ZP4>call housenumberzero.bat
C:\ZP4>C:\Python24\HOUSENUMERZERO.py
C:\ZP4\49003
C:\ZP4\49053
  File "C:\Python24\HOUSENUMERZERO.py", line 21, in <module>
    gp.CalculateField_management(fc + "\\Parcels.shp", "SIT_FULL_S", "myfunction(!SIT_HSE_NU!,!SIT_FULL_S!)", "PYTHON", "def myfunction(fld1,fld2):\n  if (fld1=='0'or fld1=='00'or fld1<'00000000000'):\n    return ''\n  else:\n    return fld2")
arcgisscripting.ExecuteError: ERROR 000539: Error running expression: myfunction("69","69 FLOOD ST
") <type 'exceptions.SyntaxError'>: EOL while scanning single-quoted string (<string>, line 1)
Failed to execute (CalculateField).
C:\ZP4>call 1LowerCaseSitusFull.bat
C:\ZP4>C:\Python24\SITUSLOWERPYTON.py
C:\ZP4\49003
C:\ZP4\49053
  File "C:\Python24\SITUSLOWERPYTON.py", line 17, in <module>
    gp.CalculateField_management(fc + "\\Parcels.shp", "SIT_FULL_S", "!SIT_FULL_S!.title()", "PYTHON", "")
arcgisscripting.ExecuteError: ERROR 000539: Error running expression: "69 FLOOD ST
".title() <type 'exceptions.SyntaxError'>: EOL while scanning single-quoted string (<string>, line 1)
JasonScheirer
Esri Alum
Try this:
gp.CalculateField_management(fc + "\\Parcels.shp", "SIT_FULL_S", "myfunction(!SIT_HSE_NU!,\"\"!SIT_FULL_S!\"\")", "PYTHON", "def myfunction(fld1,fld2):\n if (fld1=='0'or fld1=='00'or fld1<'00000000000'):\n return ''\n else:\n return fld2")
TurnerNowak
Thanks, I tried that and here is what I got:
C:\ZP44\49053 situs batch errors
  File "C:\Documents and Settings\Andrew\Desktop\Copy of HOUSENUMERZERO.py", lin
e 18, in <module>
ld2")
arcgisscripting.ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000989: Python syntax error: Parsing error <type 'exceptions.IndentationEr
ror'>: expected an indented block (line 3)
JasonScheirer
Esri Alum
Missing indentation in your function block's return statements:
TurnerNowak
Thanks, I tried the above indentation but got this error:
  File "C:\Documents and Settings\Andrew\Desktop\HOUSENUMERZERO.py", line 18, in
<module>
(" ","69 FLOOD ST
ring>, line 1)
