env.workspace - how to navigate "up" one folder?
1342
03-25-2013 08:42 AM
JT2
I am familiar with setting the env.workspace parameter in arcpy. That allows me to work within subfolders of the workspace, eg:
layer = arcpy.mapping.Layer("Sub\Test.shp")
But how do I do the opposite, ie go up one level in the folder tree?
This doesn't work:
layer = arcpy.mapping.Layer("..\Test.shp")
Is there an easy way to go up a level from the workspace path? Or is it not possible?
MathewCoyle
Honored Contributor
I don't think you can, how you envision it in any case. You can walk your workspace back one level and use the full path as a variable though.
up_one_dir = arcpy.env.workspace.rsplit(os.sep, 1)[0]
MathewCoyle
Honored Contributor
