Edits both original and new tool somehow?
3143
01-04-2016 08:34 AM
StuartKorte
I copied a custom python tool and pasted (with new name) into same toolbox. When editing the new tool, it appears to edit the original. Is this normal?
WesMiller
Are both tools pointing to the same script?
FreddieGibson
Honored Contributor
Is you copied the script the answer would be yes. Script tools will point to a script file. If you copy the script tool without copying and resourcing the script then both tools will point to the same business logic.
StuartKorte
Thanks!!! I bet that is it. We will check it out.
