Dynamic Text - limiting characters to document name
1224
06-14-2011 04:22 PM
RussellPilbeam
I've searched through the forum and couldn't find a similar question so apologies if this has already been answered before.
Within arcmap 10 looking at creating a specific map document id to display on the map layout made up of (first part of document name/company code/number field)
Its the first part of this id that i can not figure out. Example of a document name is abc123-file.mxd. What i would like to display is only abc123. Is there a way to amend the document name scripting to recognise the first part of the document name?
BruceNielsen
Assuming that the hyphen is always the separator that you're using, you can do it with the following:
filename.split('-')[0]
RDHarles
You could also use slicing:
x = "abc123-file.mxd"
# First 6 characters
print x[0:6]
>> abc123
# First 6 characters plus .mxd
print x[0:6]+".mxd"
>> abc123.mxd
