Dynamic segmentation with respect to a control factor
7734
12
05-07-2015 08:51 AM
ChukwuemekaEzeiruaku
Is there a way either with python scripts or other solution to dynamically segment the following table?
Input table (not a feature class)
Item IDBegin End
100001
100105
100217
100345
100435
Each segmented section (from-to) should have all the item numbers written to a field that is within a certain range. From the input table, the final table should look like the one below:
Output table
Begin EndItem IDItem ID
0110001001
1310011001; 1002
3410021001; 1002; 1004
4510031001; 1002; 1003; 1004
5710041002
Thanks.
BlakeTerhune
I knew there had to be a numpy solution too; unfortunately, I know squat about it. I also like your dictionary comprehension line with the search cursor better than mine. Thanks for posting, Xander Bakker
Hi Blake, your solution worked but i got an error from line 37 as shown in the image.Capture.JPG
Also i got a table with half the records from the input table.
XanderBakker
Esri Esteemed Contributor
I have marked this question as answered and branched the additional question to a new thread:
Re: Dynamic segmentation with respect to a control factor Additional Requirements
