Dynamic Labels
1331
02-20-2025 02:19 PM
DanCrawford
Hello, is there a method to grab a dynamic label from a layout for use in python?
This is the layout dynamic label:
<dyn type="project" property="name"/>
I'm building a little script to export my map to PDF and would like it to use the map name as the filename.
Thanks.
DanCrawford
I found a way using the properties of the filepath rather than the dynamic label:
import arcpy
import os
# Get the current project
aprx = arcpy.mp.ArcGISProject("CURRENT")
# Access the full file path of the project
project_path = aprx.filePath
# Extract the project name from the file path
project_name = os.path.basename(project_path)
print("Project Name:", project_name)
DanCrawford
import arcpy
import os
BlakeTerhune
There's a TextElement object you can access from the Layout object in the Arcpy.mp Python submodule. Is that what you're looking for?
DanCrawford
I'll have a look, thanks.  Also thanks for moving this post.  I couldn't find this forum thread originally.
