Dropdown menus and Keyboard shortcuts generating python error messages
982
11-05-2013 09:33 AM
JamesMcBroom1
I've got a very simple add-in that's just a drop-down menu that updates one attribute for the selected polygon. Whenever I open the keyboard shortcuts window, or, ever since I upgraded to 10.2, even click on the drop down menu containing the commands, I get an error of this type:
TypeError: isinstance() arg 2 must be a class, type, or tuple of classes and types
  File "<string>", line 1, in <module>
TypeError: 'assign_269' object is not callable
Here's a sample of the add-in:
import arcpy
import pythonaddins
mxd = arcpy.mapping.MapDocument("CURRENT")
layerList = arcpy.mapping.ListLayers(mxd)
df = arcpy.mapping.ListDataFrames(mxd)[0]
tableList = arcpy.mapping.ListTableViews(mxd)
for layer in layerList:
    if "Footprints_Edit" in layer.name:
        footprints_fc = layer
    if "Parcels_Edit" in layer.name:
        parcels_fc = layer
    if "Address" in layer.name:
        address_fc = layer
for table in tableList:
    if "Assessing" in table.name:
        assessing_table = table
    if "Condos" in table.name:
        condo_table = table
def rows_as_update_dicts(cursor):
    colnames = cursor.fields
    for row in cursor:
        row_object = dict(zip(colnames, row))
        yield row_object
        cursor.updateRow([row_object[colname] for colname in colnames])
class assign_101(object):
    """Implementation for btype_toolbar_addin.assign_civic_fraternal (Button)"""
    def __init__(self):
        self.enabled = True
        self.checked = False
    def onClick(self):
        fcount = int(arcpy.GetCount_management(footprints_fc).getOutput(0))
        if fcount <= 20:
            with arcpy.da.UpdateCursor(footprints_fc,["BTYPE"]) as brows:
                for row in rows_as_update_dicts(brows):
                    row['BTYPE'] = 101
        else:
            print "Too many footprints selected. Please select less than 20."
        arcpy.RefreshActiveView()
I have about 60 classes/buttons that all look like thatone, just the particular code is changed from 101 to some other number.
StacyRendall1
Reading the traceback it appears you are trying to access (call) assign_269, but this has not been created. You need to go through your code and check it has been created the same way as the other classes.
