Draw Perpendicular Line.
9129
7
02-25-2016 12:29 AM
RajP
Hello,
Can anyone suggest me to draw the perpendicular line for very point automatically using python/arcobject. That Perpendicular line touch with line feature. Kindly reference the below image.
Regards,
Raj
XanderBakker
Esri Esteemed Contributor
The code below seems to do the job, BUT this is based on a single line. If you have several polylines you will have to include logic to select the polyline to "snap to".
import arcpy
def main():
    fc_lines = r'D:\Xander\GeoNet\Perpendicular\data.gdb\lines'
    fc_points = r'D:\Xander\GeoNet\Perpendicular\data.gdb\points'
    fc_out = r'D:\Xander\GeoNet\Perpendicular\data.gdb\result'
    tolerance = 15000
    # get first line
    polyline = arcpy.da.SearchCursor(fc_lines, ('SHAPE@')).next()[0]
    lines = []
    with arcpy.da.SearchCursor(fc_points, ('SHAPE@')) as curs:
        for row in curs:
            pnt = row[0]
            line = createVerticalLine(pnt.firstPoint, tolerance, pnt.spatialReference)
            mp = getIntersectingPoints(line, polyline)
            if mp.pointCount > 0:
                pnt2 = getNearestPoint(mp, pnt.firstPoint)
                vert_line = arcpy.Polyline(arcpy.Array([pnt.firstPoint, pnt2]),
                lines.append(vert_line)
            else:
                # no intersecting within tolerance
                pass
    arcpy.CopyFeatures_management(lines, fc_out)
def createVerticalLine(pnt, tolerance, sr):
    return arcpy.Polyline(arcpy.Array([arcpy.Point(pnt.X, pnt.Y+tolerance),
                                       arcpy.Point(pnt.X, pnt.Y-tolerance)]),
                                       sr)
def getIntersectingPoints(line, polyline):
    return polyline.intersect(line, 1)
def getNearestPoint(mp, pnt):
    nearest_pnt = None
    for p in mp:
        if nearest_pnt is None:
            nearest_pnt = p
            min_dist = getDistance(p, pnt)
        else:
            if dist < min_dist:
                nearest_pnt = p
                min_dist = dist
    return nearest_pnt
def getDistance(p1, p2):
    import math
    return math.sqrt((p1.X-p2.X)**2 + (p1.Y-p2.Y)**2)
if __name__ == '__main__':
    main()
DanPatterson_Retired
Darren Wiens​ posted some code here ​which should get you started.  Your normals are to the X-axis rather than relative to the line.  You can construct an intersecting line relative to that axis which should give you the necessary point intersection on your line and hence the point-line segment
XanderBakker
import arcpy
def main():
    tolerance = 15000
    # get first line
    lines = []
        for row in curs:
            pnt = row[0]
            else:
                pass
                                       sr)
    nearest_pnt = None
    for p in mp:
            nearest_pnt = p
        else:
            if dist < min_dist:
                nearest_pnt = p
                min_dist = dist
    return nearest_pnt
    import math
    main()
DarrenWiens2
Are you looking for a perpendicular line (90 degrees to the line, as I've added below) or a vertical line (as you've drawn)?
he wants normal to the x-axis rather than your example of normal to the line,
RajP
I need vertical line for each point and touch with line feature.
Regards,
Raj P
M_DJohnson
IProximityOperator proximity = <<PolylineFeature>>.ShapeCopy as IProximityOperator;
IPoint out_point = proximity.ReturnNearestPoint(<<input point>>, esriSegmentExtension.esriExtendTangentAtFrom);
Try this code, it will create perpendicular lines to given point.
XanderBakker
True, but if you look at the examples you will see that it was not a perpendicular line the OP was looking for.
