Draw lines perpendicular to intersections.
1408
06-10-2014 02:23 PM
NoahHuntington
I am looking for some help with some logic regarding ensuring line A crosses line B perpendicularly.  SO far my approach has been to 1)generate points at the intersections
2)Get bearing from segment of line B where intersection occurs.
3) calculate a perpendicular bearing
I wish to take this bearing and extend it to line A then trim and clean.
The attached image and script should help explain.  I also am interested in easier logic if someone has done this before?
Thanks in advance...
Image:
[ATTACH=CONFIG]34487[/ATTACH]
    fclist = arcpy.ListFeatureClasses("Simplified_LCP_*","Line")
    for fc in fclist:
        arcpy.MakeFeatureLayer_management(sps_lines, "feature_layer")
        lyrfile = arcpy.SelectLayerByLocation_management("feature_layer","INTERSECT",fc,"#","NEW_SELECTION")
        arcpy.AddGeometryAttributes_management("sps_lines_fl","LINE_BEARING")
        count =  int(arcpy.GetCount_management(lyrfile).getOutput(0))
        if count > 0:
            # Print Intersecting line and number of intersections
            print "While examining {0}, {1} intersections were found." .format(fc,count)
            arcpy.Intersect_analysis([fc,sps_lines],Modified(fc),"ALL","#","POINT")
            for row in arcpy.da.SearchCursor("sps_lines_fl","BEARING"):
                bearing = row[0]
                if bearing >= 0 and bearing <= 270:
                    # Print intersecting line and bearing of sps line at intersection
                    perp = bearing + 90
                    print "{0}, Perpendicular value is: {1}" .format (fc, perp)
                else:
                    perp = (bearing + 90) - 360
