does the in_memory workspace be mutually influenced in every subprocess in multiprocess?
1099
03-04-2021 07:07 PM
pyfans
New Contributor II
I have write a py script with multiprocess, like this:
import arcpy
from multiprocessing import Pool
def worker(fc):
      arcpy.featureclasstofeatureclass(fc,r"in_memory","tempfc")
      ## do something for tempfc
      arcpy.delete_management("in_memory")
if __name__=="__main__":
      p=Pool(3)
      fcs=..... ## get some featureclasses
      p.map(worker,fcs)
      p.close()
      p.join()
I want to know if the created "tempfc" and deleted  in_memory workspace will be mutually influenced in  different subprocess?
JoshuaBixby
MVP Esteemed Contributor
Processes within a pool don't share memory unless objects are passed as specific multiprocessing data types, e.g., multiprocessing.Array .  Since you are not doing that in your code (I am not even sure any ArcPy objects can be passed that way), the in-memory workspace in each worker process is independent of the others.
An example:
import arcpy
import time
i = 0
def f(x):
    global i
    i += 1
    arcpy.CreateTable_management("in_memory", "xx{}".format(i))
    time.sleep(1)
    arcpy.env.workspace = "in_memory"
    return arcpy.ListTables()
if __name__ == '__main__':
    with Pool(4) as p:
        print(p.map(f, range(6)))
Yields:
[['xx1'], ['xx1'], ['xx1'], ['xx1'], ['xx1', 'xx2'], ['xx1', 'xx2']]
As you can see, each of the four worker processes is able to create the same-named table in its in-memory workspace, and each arcpy.ListTables() only sees the tables in its own in-memory workspace.
JoshuaBixby
An example:
import arcpy
import time
i = 0
def f(x):
    global i
    i += 1
    time.sleep(1)
    with Pool(4) as p:
Yields:
