disable m and z values
6454
08-29-2013 06:49 AM
jonathantuscanes
I am working in on a geoprocessing python script (10.0).  My issues is the following error:
ExecuteError: ERROR 999999: Error executing function.
Invalid Topology [M coord limit exceeded.]
I am aware on how to disable m and z values in ArcGIS GUI, in the 'Environment Settings'.  However, I can't figure out how to do this in a python script.  I tried this and it did not work:
arcpy.env.outputZFlag = "Disabled"
arcpy.env.outputMFlag = "Disabled"
I am also aware that converting the FC to a shapefile will strip any m and z values....but I would like to continue my work inside a FGDB.  Hopefully I am missing something obvious.
StacyRendall1
Setting the value works for me. You could try printing the values before and after your assignment to confirm this:
arcpy.AddMessage(Z: ' + arcpy.env.outputZFlag)
arcpy.AddMessage('M: ' + arcpy.env.outputMFlag)
It may be that the variable is being set, but some tool later on is not honoring the setting.
